Dirt in engine
Old 03-25-2013, 07:15 AM
Default Dirt in engine
What are the signs that you have dirt in your nitro engine?
dazablue is offline
Old 03-25-2013, 07:27 AM
Look in the carb if u see any dirt, the engine might start but will flame quickly, u need to take the engine apart if u suspect any dirt went in, clean everything with some nitro cleaner prolly replace bearings, the dirt will wear down the psr and crank, put in a new plug, u will lose a lot of pinch if u r lucky it might still run but most likely its finished if it got dirt in it
NitroXray is offline
Old 03-25-2013, 08:54 AM
Rcrenew's Avatar
If you see any dirt in carburetor throat, Scuffing or scratches on crankshaft,case, Piston,sleeve. Bearings may also be worn or feel gritty or not smooth. Also check for a grey dust/ past inside. The dirt is like sandpaper on the aluminum and steel parts.
We rebuild/ repair a lot of engines if you have any questions feel free to give a call or email.
Rcrenew is offline
Old 03-25-2013, 11:29 AM
token's Avatar
When you open it and it has dirt inside...
token is offline
