Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
To oil or not to oil..that is the question >
Old 01-23-2013, 08:50 AM
tank1023's Avatar
Default To oil or not to oil..that is the question
The track I go to is VERY dusty, I've noticed that when I oil my filters they get very gummed up and seem to heat up the car. Would I be better to leave it dry so the fine dust doesn't clog up the filter?
Wouldn't the two layers of foam stop the dust from getting into the carb?
tank1023 is offline
Old 01-23-2013, 08:53 AM
I oil the inner and not the outer...it makes it easy to do a quick clean on the outer if the day is real dusty and any thing that gets through will definitely be stopped by the inner...imo
motoclay is offline
Old 01-23-2013, 09:02 AM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Personally I oil both inner and outer, I don't trust one oiled filter but I run expensive engines so it's a precaution. In also run a filter mesh from outerwears, it keeps the filter clean. I swap out my filter after each race or practice day.
bigjayjay1 is offline
Old 01-23-2013, 09:10 AM
BMenard17's Avatar
Trader Rating: 88 (99%+)
Use some self sticking band aid type wrap to cover your filter I think it known as vet wrap... Ill get a link to what I use in a few. I found it at Walgreens
BMenard17 is offline
Old 01-23-2013, 09:29 AM
banana rt's Avatar
oil it both inner outer, make a thin oil. change your filter after a few run. depends on how much dirt covering your filter. it doesnt gonna hurt ur engine running much filter oil,
save ur powerplant !!
banana rt is offline
Old 01-23-2013, 09:33 AM
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 205 (100%+)
lack of filter maintenance is quite possibly the biggest killer of all.....
ALWAYS OIL, soak them up, squeeze out excess, then dry dab them until they are sticky, not soaked, just enough to trap particles, dont starve your engine for air by over oiling...
buy a BUNCH, change them every heat....clean/re-oil, re-install....every day, every heat....change your filter elements all the time
Trevor Williams is offline
Old 01-23-2013, 09:35 AM
I oil both, thin on the outside and alittle thicker on the inner.
token is offline
Old 01-23-2013, 09:51 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
I run pre oiled filters and I like the outer element dry or mostly free from oil. I have had the outer element clog up with dirt if it had too much oil on it and then the engine tune changes. I have tried many different filter brands and the losi filters seem to keep more dirt out. Also toss it when it's done. There is no way to clean it completely. These little engines are very sensitive to dirt, not like other larger engines where you can clean the filter and be ok. So replacing it with a new oiled element is cheap insurance.
Frank L is offline
Old 01-23-2013, 10:20 AM
Upbasher's Avatar
I run the outer one free of oil and make sure the inner one is oiled nice and thick.
Upbasher is offline
Old 01-23-2013, 10:22 AM
motor spray will clean them everytime Frank, but yes you are correct, they are cheap enough to NOT re-use.
Old 01-23-2013, 11:40 AM
Trader Rating: 6 (88%+)
Hot water wd40 and dawn soap doesn't get much easier than that. I man that has been in the industry for 25+ years and has traveled the world working and driving these things taught me that.
Drip is offline
Old 01-23-2013, 11:54 AM
sschultz's Avatar
Trader Rating: 15 (100%+)
+1
and filter oil.
sschultz is offline
Old 01-23-2013, 12:06 PM
tank1023's Avatar
Nice thanks for the tips
tank1023 is offline
Old 01-23-2013, 01:48 PM
Trader Rating: 45 (100%+)
I clean the outer filter with nitro and then spray motorcycle filter oil on it once every race day or when they get dirty ,the inner filter stays nice and clean , over 20 gals on a grp with no problems,,
rc racer 103 is offline
Old 01-23-2013, 04:08 PM
Akhor's Avatar
This is exactly what I do.. Never had an issue yet.
Akhor is offline
