Pipe/parts Polishing Service
#92
what method do you use to "pull out" dents?? Ive heard of guys filling pipe with water, putting in freezer to pop dents out, but I also heard of guys splittling a pipe in this way. Just curious what you do. I never worry about dents. Most are so small, I dont think it affects perormance..
#93
the guys the split pipes probably completely block the ends with solid material and filled the pipes all the way... i fill the pipes all the way and use some sort of seal that stretches...
works great... some dents you may have to do that process a few times
#95
fill it with water.. and cover the ends.. i use a piece of latex glove.. if its thin i just double up and hold in place with zip ties.. on the nipple i use the normal stuff that comes on the carbs... let it freeze.. shoudln't be more than an hour.. before you can check it...
#97
#102
Thanks Houston....
This thing went really good for a few months last year.. but Im not sure what happened, RC Tech changed some guidelines and took down my post or moved it, I cant remember. Something about couldn't advertise a business in the engine section... I don't exactly remember. When they did that, business died instantly because no one was searching for it. Anyway... someone emailed me a few days ago asking if I still offered this and had a boatload of pipes he needed done. Thought Id give this post a quick bump and see how it goes.
THANKS bud
