-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Dirt in pull start (https://www.rctech.net/forum/offroad-nitro-engine-forum/689703-dirt-pull-start.html)
turbo5513 12-27-2012 11:44 AM
Dirt in pull start
So I just took my truggy bashing on a gravel soccer field and then brought it home and washed it with the hose pipe. (Its waterproof). Then I went to apply after run oil in the engine and when I went to pull the starter it did not want to take the rope back. I wiggled it a bit and i went in but the tension of the rope is a bit loose when the rope is inside and the handle attached to the rope is dangling instead of standing in the hole for the rope.
sschultz 12-27-2012 05:51 PM
take it off, carefully not to separate rope spool from housing, blow it out while pulling rope out making sure spool doesn't come out of housing. Spray it with wd-40. re-assemble...
turbo5513 12-28-2012 03:27 AM
Thanks sschultz, its working great now!
blis 12-28-2012 03:41 AM
bravo
You mean yours didn't erupt into a intertwined spiraling knot? Well done!
dooug1960 12-28-2012 07:43 AM
been there done that! second pull on my first engine i had the handle in my hand and i got to learn how to rewind a pull start at that moment not fun.
sschultz 12-28-2012 07:52 AM
:nod::tire::tire::tire:
