Picco Boost 5TR 2012 .28 Off Road Pull Start Engine
#16
Can i buy it directly from you?
#17
#18
Picco Boost .28 Roto Start engine is now available. as well as seperate Roto starts to convert your pullstart engine.
http://tritonrc.com/picco%20engines.htm
#20
$34 for the new Roto unit
#21
Couple questions about the Boost .28 with pullstart.. I have several kinds of RC's I'd conceivably put it in - Losi LST2, Ofna DM-1, SC8.. Anyway, I'd want the pullstart so I could put it in the LST2 if I want.. I'd also like to be able to run the DM-1 without a box..(PIA always having to change mounts so it can share the box with my buggy..) Anyway, years ago I read that the Mach .15 backplate fit the Picco P3 .28 for use with a Losi Spinstart... Any confirmation on that? Also, can you put a closed backplate on it for use with a starterbox the way you can with the LRP's and co.? Thanks..
#22
I cant not give any info as I have never tried using those different parts, but maybe someone who has will chime in
#23
Availability for this engine absolutely sucks. Not available at all in Germany, and not available at Amain or Tower..
#24
