byron fuels?
after a 9 year hiatus from the hobby I bought a buggy to bash around with. since i love the size, speed, and brute of these bad boys.:nod:
anyway, stopped in the local hobby shop and they had 3 choices of fuels. wildcat eliminator, sidewinder race blend I think it was and byron race 2500. he said the byron gen2 2500 is the most pop choice. it's 25% nitro and 11% oil. I really wanted something that was for offroad not a actual race fuel.. I bought the byron 2500 based on it being the best seller. before I open it I wanted to get some pro's opinions first. I'm not concerned with all out racing power potential as I am engine protection from a high quality fuel. did I get a decent fuel that will work with a off road buggy and provide ample protection? |
That will be just done for bashing.
I kind of figured it was. but in the world of sportbike racing, you're not supposed to use race oil in a street bike or race brake pads etc etc.
they're not designed for it. so with that kind of background had me suspicious of using race fuel for play. |
The Byrons 25% ¨Race¨blend fuel (11% oil) you have will be fine for play or racing.
Byrons also make the ¨Pro Driver¨ blend which is 9% oil, and more of a serious racer fuel, but can also be used equally as well for play. If your new to nitro stick with the 11% blend for a while until your tuning skills develop. The 11% just gives you the extra lee-way should something go astray in the tuning department :) Byrons Gen2 Race or Pro Driver blends are excellent fuels. We stock Byrons and recommend it to all our customers. |
Yep
as far as I'm concerned Byrons 25% 11% oil. is the best all around fuel. I race with it.
Can't go wrong with Byrons 25/11 or 30/11. I actually buy the 30/9 pro driver blend and add an ounce of castor oil to the gallon (takes it to about 30/10) since my lhs / track only carries the 30/9 in stock. IMO, Byrons has some of the best, if not the best oil package in the industry.
Even if you don't race. Byrons is one of the best and I've used a lot of different fuels. VP Powermaster and Byrons are what I've had the most success with however I havn't tried Werks fuel which I've heard great things about.
Good to hear this. This is what was reccomended to me when I first got a Nitro. been using ever since (just over a year).
Picked up 4 gallons through Amainhobbies earlier this year. |
noob question here, my car is an xray xb8, I did the break in with 20% nitro and 16% oil byron race gen2, after break in and one race I end up with almost a bottle of fuel left, but in my hobby shop i bought the last galon left byron race gen 2 but it is 20% nitro and 12% oil, should i mixed them? or should i finish first the 16% then start with the 12%, if so how do i prepare or what should i keep in mind for changing fuel
thanks in advanced |
Originally Posted by ArsNova
(Post 13927437)
thanks in advanced I would finish off the first and then switch to the other. When you switch, you will need to adjust your tune. It should run a little rich until you do. Good luck. |
Originally Posted by Jerm13
(Post 13927497)
Go ahead and put the shovel away. You did a good job of digging up a old thread...:lol: Just giving you a hard time BTW.
Originally Posted by mtpocketsracing
(Post 11434795)
anyway, stopped in the local hobby shop and they had 3 choices of fuels. wildcat eliminator, sidewinder race blend I think it was and byron race 2500. he said the byron gen2 2500 is the most pop choice. it's 25% nitro and 11% oil. I really wanted something that was for offroad not a actual race fuel.. I bought the byron 2500 based on it being the best seller. before I open it I wanted to get some pro's opinions first. I'm not concerned with all out racing power potential as I am engine protection from a high quality fuel. did I get a decent fuel that will work with a off road buggy and provide ample protection? 'AC' |
Is Prodriver's oil package semi-castor/semi-syn like Race fuel line? Or it has full-syn oil?
Originally Posted by vandalzzz
(Post 14145630)
Originally Posted by bash bros
(Post 14145881)
Pro Driver is also synth/castor blend.
| All times are GMT -7. It is currently 06:43 AM. |
