Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
havnt used my engine in over a year... >
Old 10-08-2012, 12:01 PM
Default havnt used my engine in over a year...
Hey guys. been a while.. actually according to my last visited date, tomorrow would have been exactly 1 year since I logged on!
anyways, its been about the same amount of time since ive ran my buggy.
I have a lrp.32 engine in a mbx5 muggy. the engine is pretty new. only 3 or 4 tanks of fuel through it.
last time I drove it it ran fine, I burnt about 2 tanks of fuel with the girlfriend in an open field doing lots of top speed runs.
packed it up and havnt touched it in over 12 months.
I just tried pulling the pull starter slowly and it felt like it was dry inside or something.. so I stopped. and took it all apart. everything seemed fine still except for one thing.
when the piston hit TDC it would kinda get stuck in the sleeve... I took the sleeve out and the top part of the inside of it looks like the piston scuffed/polished it a little bit.
did I leave my engine sit for too long? is that why youre supposed to let it sit at TDC for long periods of time? seems like the part of the cylinder that had piston touching it is fine, but the top part of the cylinder seems to have gotten smaller, and is now not letting my piston go up and down smoothly.
any advice?
whatsitallworth is offline
Old 10-08-2012, 02:26 PM
Trader Rating: 2 (75%+)
From what you're saying, I would say your engine is pretty new. It needs to broken in? To help with the starting I'd suggest using a heat gun or blow dryer to heat the engine up so the materials expand. Pulling the starter should be easier by then.
To answer your question, your engine is perfectly fine. Just look at the break in bible in the engines section and follow the instructions. At the end of the break in your engine should be working great.
Your engine has mechanical pinch.
Hope this helped
fung_kyle is offline
Old 10-08-2012, 04:37 PM
Stubbs's Avatar
Trader Rating: 58 (100%+)
These two sentences mean bad things.....first, and engine that only has 3 or 4 tanks run through it is not broken in. Second, an engine that is not broken in should not be run at high RPM / full throttle.
Basically, you stressed the snot out of your engine with those top speed runs, and likely reduced its life considerably.
That sticking when you push the piston up is the mechanical pinch...it's supposed to be there on new engines.
Stubbs is offline
Old 10-08-2012, 07:07 PM
mx51's Avatar
And to add to what stubbs said you do not want your engine sitting at TDC after running it you should always put it to BDC (bottom dead center)
mx51 is offline
