Which OS engine ?
Old 09-14-2012, 10:38 PM
Default Which OS engine ?
I am planning to buy a new OS engine, for my buggy.
I am between xz-b blue head and the hara edition speed.
Which one you recommend? Which one is more durable?
what is the differences between the 2.
I am reading that the hara speed is similar to the speed, is it true?
mike80 is offline
Old 09-14-2012, 10:57 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
Being the hara is 2x I don't understand the comparison.
The hara is softer on the bottom and screams higher on the top. You will also see more mileage with the hara. Personally I like the hara engine but it's a little soft on the bottom for some.
Btw where are you getting the hara from?
Frank L is offline
Old 09-14-2012, 11:01 PM
I will get it from a hb distributor.
Which one is more durable ?
the blue head or the speed hara?
mike80 is offline
Old 09-15-2012, 12:45 AM
22Racer's Avatar
Trader Rating: 67 (100%+)
I have heard the xz-b blue heads still have some crank wear issues.
Rex
22Racer is offline
Old 09-15-2012, 04:52 AM
Frank, thank you for your response.
I have heard the the hara speed edition in a very good engine but it is not as durable as the xz-b blue head or the xz-b speed is that true?
out of the three, which one you recommend ?
mike80 is offline
Old 09-15-2012, 06:30 AM
Frank L's Avatar
I have no issues with the Haras that I run. I have one in my buggy now that has 3 gallons in it or so and it runs great and still has nice compression.
Frank L is offline
Old 09-15-2012, 06:38 AM
Rcrenew's Avatar
The Blue head XZB still have crankshaft pins wearing out prematurely. If you get an OS get one with a DLC coated crank.
Rcrenew is offline
Old 09-15-2012, 10:40 AM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
I would get the hara its a awesome mill it has great top end and a smooth bottom. It has power make are you run the right pipe
bigjayjay1 is offline
Old 09-17-2012, 05:28 PM
Zerodefect's Avatar
Not everyone has had the crankpin problem.
I've only got 2 gallons on mine, I won't know about mine until the end of next season. I'll bet fuel and tune are part of the issue. Cold starting maybe as well. I heat up for a half hour with a comp heater before my heats. I've had great life from other engines by heating them up and running in the pits for a little while, then shutting down and carrying them to the stand warm just a few minutes before my run, and restarting.
OP, If you don't KNOW that you need a OS Speed, then you're throwing money away. Get the regular XZ-B, or if you want the DLC crank, get the OS/Ninja JX21 BO2. Just by asking "Do I need a Speed?", kinda means you likely don't need a Speed.
The Fusion engines are also something you might want to look at.
Zerodefect is offline
Old 09-17-2012, 05:37 PM
kgombe's Avatar
just get the ninja B02.. best of both worlds.. good price and DLC crank.. and it out right screams
kgombe is offline
Old 09-17-2012, 06:11 PM
Suspended
Trader Rating: 7 (73%+)
Why not buy the best engine? Novarossi.
chopper82p is offline
Old 09-17-2012, 07:35 PM
CKmaxx's Avatar
Why not keep your posts in the appropriate thread??
CKmaxx is offline
Old 09-18-2012, 05:42 AM
Zerodefect's Avatar
I might want to run a NR in the future. For now I'll stick with OS until I feel that I want to challenge myself again with an engine that's a pain to tune, uses crappy glow plugs, and takes forever to break in wasteing too much fuel.
Fusion Engines are NR based but come with better details. (3 port with a turbo head, ceramic bearings, etc.etc.) They also have a 7 port Bonito like engine that deosn't quite have the Bonito price tag.
Old 09-18-2012, 06:17 AM
Buy one that has a DLC crank.
Personally I've not tried the Ninja B02, but I still run my B01A occasionally, and it's been a great engine for me.
Eivind E is offline
Old 09-18-2012, 06:46 AM
Maximo's Avatar
Put a OS plug into a Nova........ works like a charm and makes engine tune much like a OS !!
Less money then a Bonito, but less performance then a Bonito too...so its all in perspective....
Novarossi have ceramic bearings and turbo heads too.......lol...except a 4 port not a 3 port....4 port is better than 3 port..which is why Nova dropped 3 port in favor of 4 port in their regular lineup........
Maximo is offline
