Originally Posted by GizmoJunkie
(Post 11034795)
See i was trying to look up to see if it was what they call "pinging" or pre-detonation. Looked for a video and couldnt find one :confused:
I havent had the issue since last year, usually it does it when engine is hot, say above 250. Exception being the first run i had this year. I couldnt get the engine to stay above 200 and it was kinda lean at that. Hasnt done it since. I have opened the engine up a few times, even recently and havent seen any signs of pre-detonation such as the grainy surfaces. The noise im talking about usually happens when idling down from a lean top, while the engine is up to temp. Not sure if this was a lean thing or a "ping". I was thinking if i encounter this again id use a colder plug. If i come across being unable to temp above 200 again would you suggest a hotter plug? Just a quick edit to add: I feel im fairly competant as far as tuning goes, I always tune to performance but use the temp gun to make sure im in range. It does however get a little hazy on plugs. I know hot weather means use a colder plug, but humid weather means use a hotter plug. What about hot AND humid? Its like guesswork so far and trial/error to see what performs best on those days. I was curious whether that was tune, fuel, or glow plug..... |
Originally Posted by XtremeJumpin16
(Post 11035294)
How do you do the spit test?
boils off in less than 1-2 sec = too hot boils off is 4-5 sec = good temp just sits there, and doesn't boil off = too cold. |
Originally Posted by Stubbs
(Post 11035575)
I was thinking of something completely different. I've had instances where my engine was up to temp, and I was doing some runs up and down the front straight on my local track to dial in the HSN, and I could hear some "pops" as it was running at high RPM.
I was curious whether that was tune, fuel, or glow plug..... I havent heard a "pop" come from my engine. Does it sound like a backfire or something? I honestly dont know that ive ever heard one? The noise i heard was pretty strange, at this point im really starting to think that i was a touch lean up top, and using a glow plug that was hotter than i needed that day. Like I said hard to describe. maybe like the engine wasnt firing once every 4-5 stokes? Hell maybe it was a bad plug, its been changed since lol. |
Skipping may be
Lean HSN and Large idle gap. In combo after a fast run you come to neutral and hear a skipping sound. Good to see people forgetting the temps. Tune the engine for performance always. Remember temps are suseptable to and will vary up to 20 + deg C depending on temp gun Your fuel Shimming Pipe Air filter Emmesivity of the alloy the head is made from Chassis Engine mounts Tyre choice Diff silicone selected Clutch Ambient temps bla bla bla Ok SO forget temps. If the engine is running badly you will hear it. it will sound like a cat having a bad day in a blender. Smoke trail is also a little tricky. Some fuels smoke more than others. a good fuel will have a medium smoke trail but that depends on the tune. When you tune for ultimate performance you should not see any smoke at any stage. refer to some videos of top drivers in the world on and off road. You will see virtually no smoke trail. This is due to the fuel being of higher quality and a really lean mix, perhaps just on the rich side of too lean. This condition is for max power and run time. Not recommended for beginners. Oil coming out of the pipe is actually a good sign but only a few drops here and there. If its oozing out then its too rich. Fuels that smoke very little is an indication of high quality synthetic. The higher quality synthetics will have a much higher flash point so they dont burn off as much in the combustion process. this is good because you need lubrication on the down stroke too. Great thread and lots of good info , sorry for blathering lol M |
Originally Posted by MassiveMods
(Post 11047991)
Skipping may be
Lean HSN and Large idle gap. In combo after a fast run you come to neutral and hear a skipping sound. I was total noob with nitro last year, and getting into it this year I now have a better understanding of it. I just remeber it running like this last year, and then the first run I had of it this year. It has since been retuned, so for now the problem is solved lol. Thanks again ;) |
Very very very common tuning mistake
Some engines will run fine like that and many will not |
Mine has always ran like a beast, just sounded odd like that off throttle.
Either way I can add that to my book of knowledge of what to look for if i come across it again. Might be able to help another total noob at the track with it one day lol. Its amazing how you idle air gap can contribute to a LOT of strange happenings. :lol: |
(Post 11049564)
I remember doing a whole tuning guide, using pictures in one of those threads, showing idle gaps and fat bottom ends, etc etc etc :lol:
Those that seen it will know why I'm :lol: hehehe :D |
(Post 11035647)
See now some of the other things that i have read was that pre-detonation is usually right around the max rpm that you can make. Perhaps that is the pop you are hearing? I do believe a change to either nitro content, head shims or colder glow plug might be needed in that case.
Engine tune is an art, get help at the track from someone who is experienced if you're struggling.
You want to be blowing white smoke, have good top end performance. The bottom end response wants to be crisp, but you want it to idle well. Be within 200-260f depending on the engine, temperature is purely just to check the engine isn't cooking it's self. The plug wants to look nice shiny, undistorted and be ever so slightly wet to touch. Be aware though! If your clutch settings are off, you're never going to get a good tune. If your plug is old, you're never going to get a good tune. If you have a pipe that is too long or short, you're never going to get a good tune. If you've got a damaged engine, you're never going to get a good tune. If you've not got good seals from your exhaust gaskets, you're never going to get a good tune. |
Originally Posted by JamesHealey
(Post 13331247)
for their set-up without dyno testing? Bill M. |
I think worrying about 'dyno testing' shows a misunderstanding of nitro car racing at it's best...
Track Time is the only testing you need for all questions regarding best performance and best runtime. Dyno will not show you how changing track conditions plays a GREAT influence when it comes to best performance and best runtime. Learning clutch setups to match changing track conditions alone takes Track Time and plenty of it. Best Track Time is right after the mains at your local track! |
I really appreciate what you are saying, and I am not saying a dyno is all important,
but like I have mentioned before, there is many myths about pipes. The idea that there is multiple pipe set-ups because of track conditions is one of those myths, and a source for fuel economy issues. The best pipe and engine combination is created completely separate of an track conditions. An engine set up this way will have the best acceleration before and after the peak, and the greatest peak HP. Then it is up to the tuner to adapt that set-up to the current track conditions. Bill M. |
Your statement would make the many engines that get best performance with a Werks 2058 a myth but we know different...
I hear ya bro and I know where your mindset is and it's not going to change anytime soon, good luck and above all have fun at the track! |
| All times are GMT -7. It is currently 02:07 PM. |
