Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
hudy engine bearing tool question >
Old 06-03-2012, 09:55 AM
tony montana's Avatar
Trader Rating: 73 (100%+)
Default hudy engine bearing tool question
Looking at this, Hudy Ultimate Engine Tool Kit (.21 Engine w/14mm Bearing)
[HUD107051] was wondering does it come with everything I need to pull and install bearings for o.s. and nova type .21 engines?
tony montana is offline
Old 06-03-2012, 12:59 PM
The HUD107051 should come with everything you'll need. I just recently changed the bearings in my p5 with it.
FLDan is offline
Old 06-03-2012, 06:04 PM
thank you sir
Old 06-03-2012, 06:06 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
Everything for .21 is fine. The only thing I had to buy extra was a collet for pulling the .19 rear bearing. Kevin and I both use this one.
jmackani is offline
Old 06-08-2012, 08:56 AM
bcarter007's Avatar
Trader Rating: 96 (100%+)
bought one 2yrs ago....absolutely best $100 ive ever spent.....u will loooove this tool tony
bcarter007 is offline
Old 06-09-2012, 07:07 AM
racarb's Avatar
yeh you get what you pay for...very good tool.
racarb is offline
Old 06-09-2012, 09:27 AM
Stubbs's Avatar
Trader Rating: 58 (100%+)
I've always used the "oven method", but my most recent bearing change didn't work out very well.
I had to get the LHS owner to help me get things straightened out. I used to think they were a "luxury item", but after feeling how easy it was to both remove and install bearings with the proper equipment, I'll be buying a bearing tool.
It's precision fit, with precision parts.....you're better off with precision tools.
Stubbs is offline
Old 11-01-2012, 03:24 PM
Lille-bror's Avatar
Hi.
Can you install a 14.5 mm bearing with the presser from the # 107051 set?
If I need to remove a 13 mm bearing I'll need part number #107063. How do you install a 13 mm bearing? Also with the presser that is included in the .21 set?
Lille-bror is offline
Old 11-01-2012, 03:58 PM
houston's Avatar
Originally Posted by Lille-bror View Post
Hi.
pretty sure it comes with whole 13mm shaft Bjarne , look at the pics of included parts
houston is offline
Old 11-02-2012, 12:38 AM
Lille-bror's Avatar
Thanks Monty. It is just, whats the outer diameter on the presser adaptor #107073? Both the "rod" and the big thing you use for pressing in the rear bearings?
Copyright İ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
