Losi clutch bell assembly?
Old 04-10-2012, 09:49 AM
Bansh88's Avatar
Default Losi clutch bell assembly?
I'm about to rebuil my 8ight-T clucth. Everything was pretty much smashed and fell apart.
The one thing I'm not sure about are the shims. What size, how many and where? I've only found one exploded view and was not helpful.
This will be a Losi 14t bell on a Losi 4-shoe clutch if that helps.
Bansh88 is offline
Old 04-10-2012, 10:23 AM
LOSA6356 or LOSA9106
token is offline
Old 04-10-2012, 11:07 AM
Bansh88's Avatar
I have the shims. Just dont know where they go. On both bearings? 1, 2?
Bansh88 is offline
Old 04-10-2012, 11:29 AM
Maxxed-out's Avatar
Trader Rating: 15 (100%+)
Add shim/shims between clutch nut and inner bearing (bigger bearing) so that your bell doesn't rub the flywheel (I use 2). Shim between outside bearing (little bearing) and clutch spacer to get the proper clutchbell play, Manual says .25 -.50mm.
Maxxed-out is offline
Old 04-11-2012, 12:42 AM
I am is sort of the same jam. I am installing a new engine, and I am following the manual. But, when i put 1,2,3, or 4 shims against the flywheel nut, and tighten the clutch bell screw into the crankshaft, everything gets tight and the clutch bell doesn't spin freely. with 3 or 4 shims and tighten, i get a bumpy feeling when i try to spin the bell. kind of like a bearing with a flat spot. when i disassemble and check the bearings I don't feel anything. hand pressure on the bell doesn't dot it either. only upon tightening the bell screw.
carpenterkc is offline
Old 04-11-2012, 06:46 AM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
You guys need to play with the spacing just add or take out shims right after the clutch nut. As you add or take out the spacing between the top of the crank and clutch bell will move.
bigjayjay1 is offline
Old 04-11-2012, 09:02 AM
I've been doing that. Too few shims and the center of the bell grinds on the inside of the clutch assembly. Added more shims and that went away. But when I tighten the bell screw I get into trouble. I suspect its in the bearings but I have to get some more to verify. They feel smooth until I tighten the bell screw.
wow, rookie mistake. It seems that the new clutch collet that came with my new nova plus 28-7t engine is not compatible with the losi 8ight-t 2.0 rtr clutch and flywheel assembly. the clutch wasn't going far enough back on the crankshaft for it to go through the outer bearing. after the swap the flywheel dropped back right where it was supposed to and everything else fit perfect. that is unless there is something i'm not seeing. i hope it all holds together for break-in!
Old 07-11-2019, 06:32 PM
srt4johnny's Avatar
Bump this back up since itís the same problem Iím having. Only difference is Iím already using the Losi shorter collar and this is on a Nova Rolling .21 , any other suggestions to getting the end of crankshaft out further past front bearing so when I tighten things up it doesnít bind. Right now end of crank is a good 1/8 inch short of flush with front bearing
srt4johnny is online now
Old 07-11-2019, 07:54 PM
JakeS924's Avatar
Thereís many tutorials on YouTube on how to shim your clutchbell. Adam Drake probably has one.
JakeS924 is offline
Old 07-11-2019, 07:57 PM
JakeS924's Avatar
Nevermind, I read your problem backwards as in the shaft was sticking out past the bearing.
JakeS924 is offline
JakeS924's Avatar
(Ignore this, accident)
JakeS924 is offline
Old 07-12-2019, 04:06 AM
timjs's Avatar
You need an M3 by M5 spacer to "extend" the crankshaft. This kit has a couple.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F19 2706257329
timjs is offline
Old 07-12-2019, 05:45 AM
srt4johnny's Avatar
That link didnít work. What about filing down the Losi collet to bring flywheel closer to engine someone had mentioned?
Old 07-12-2019, 07:48 AM
srt4johnny's Avatar
Old 07-12-2019, 08:36 AM
srt4johnny's Avatar
If I did file down the collet which end do you guys think I should shave off?
