"Batteryless" glow plug igniter
Old 03-07-2012, 08:46 PM
DLF
Default "Batteryless" glow plug igniter
Currently, I have the Ofna glow plug igniter for 12V (http://www.amainhobbies.com/product_...r-w-12V-Driver)
I love the thing. Problem is, it's for 12 volts and I'm going to a new box using two 7.2 volt packs.
Does anyone make something like this that will work at 14.4 volts?
DLF is offline
Old 03-07-2012, 08:58 PM
SolderGlob's Avatar
Why not use a single cell igniter?
SolderGlob is offline
Old 03-07-2012, 09:52 PM
Zao18's Avatar
Because it's one more thing to charge. The guy is just trying to keep things simple and use a glowplug igniter that runs off his starter box battery. It's also a great way to keep your igniter from "wandering off" and getting misplaced. No one will wander off with it if it doesn't have its own battery .
In regards to the original question, unfortunately you'll likely have to solder your own resistor into the igniter circuit to drop down the voltage to 12v.
Zao18 is offline
Old 03-07-2012, 10:00 PM
ekt
ekt's Avatar
I use the same thing, instead of using 2x2s in series in the box, I use 2x3s in parallel.
ekt is offline
Old 03-07-2012, 10:31 PM
Maximo's Avatar
it will work fine on 14V..just turn it down a little..I use a 2C Lipo all the time with mine...no issues at all
Maximo is offline
