Werks B6 tuning help
Old 02-28-2012, 01:28 PM
Locum51's Avatar
Default Werks B6 tuning help
Okay, i've had this motor since last season and i could never get it to fully run correct.
Stats to get you up to speed...
Werks B6 with ~5gals, og everything
P3 plug (picture to show plug state)
temp of 210F during idle (video will be provided showing so)
idle gap of 1.5mm (picture to show will be posted)
fuel filter is being used currently but it also happened when i was straight line.
At time of video, needle settings were 1 1/2 turns in on lsn, and flush with top on hsn.
I do like always and reset everything to flush, start with an idle gap of 1.5mm and let it idle for a bit, however....
Any time any throttle is applied, it randomly dies...*no matter what lsn setting i have it on*
WARNING!! VIDEO IS LOUD, TAKEN WITH IPHONE
Last edited by Locum51; 02-28-2012 at 01:30 PM. Reason: forgot warning and other stats
Locum51 is offline
Old 02-28-2012, 01:31 PM
stallen50's Avatar
Trader Rating: 30 (100%+)
idle gap way to big. should be .5-.7mm. you should barely see it with the stock venturi in
stallen50 is offline
Old 02-28-2012, 01:37 PM
Locum51's Avatar
Really? I was told 1mm-2mm by werks on here.
Locum51 is offline
Old 02-28-2012, 01:40 PM
stallen50's Avatar
i would reset your needles and idle gap to .5-.7 and retune. and hopefully fixes your probs
Old 02-28-2012, 01:43 PM
nitroexpress's Avatar
I don't think so. Maybe +1mm for break in, but not for running.
That black plug shows you're super rich. Close that baby down.
nitroexpress is offline
Old 02-28-2012, 01:51 PM
Locum51's Avatar
Better?
Locum51 is offline
Old 02-28-2012, 02:45 PM
If I told you that then it was for break in. Normal air gap setting for a broken in engine is approx 0.5mm. As others have said reduce the air gap and lean the LS needle down until you get a smooth steady idle. Then tune from there. If you have any other questions please post them on the B6 thread so that the forum does not get cluttered up and I'll be happy to help you out
Werks is offline
Old 02-28-2012, 04:07 PM
[QUOTE=Locum51;10395872
Better?[/QUOTE]
You did set the gap with the restrictor out, right?
Old 02-28-2012, 04:16 PM
Locum51's Avatar
Alright, just wondering for now as I have yet to test the new air gap but if I have the same problem with the engine randomly dying when throttle is applied...what could that be? (trying to soak in as much info as I can while my brain is still young.)
Locum51 is offline
Old 02-28-2012, 04:18 PM
Locum51's Avatar
Yes, I didn't have much time to be exact in my measurement, it was a by eye measurement with the resistrictor out yes.
Locum51 is offline
Old 02-28-2012, 04:25 PM
stallen50's Avatar
how are you tuning the motor? high first or low end?
Old 02-28-2012, 04:42 PM
Locum51's Avatar
Always low end first, after air gap is set. And I'll rev in between lsn adjustments.
Locum51 is offline
