not pulling fuel
working on a buggy for a buddy of mine and having some issues.
its a GS storm and has an HPI .21 motor. we cant make it pull fuel to save our life. if we prime it by blowing fuel into carb, it will fire up first try, but it wont pull on its on. we checked the base of the carb and back plate, but cannot find a leak. also tried new fuel hoses, etc. can anybody give me some ideas as to where to go to next? i know the motor runs, but without the vacuum, the motor wont pull the fuel. this thing has stumped me for going on 3 days! |
Originally Posted by zkid09
(Post 10344766)
There are actually quite a few reasons you have no pressure. Of course they all have to do with an air leak or blockage.
Front bearing on the engine is leaking. Engine case has a crack somewhere. Fuel tank has a split at the seam, or a crack, or a hole Pipe has a clog in the pressure nipple Pressure nipple on fuel tank is clogged. Pressure line has a hole in it. Cooling head and button are loose Carb is not tight. Pinch bolt leaking. Hole in the carb slide boot. Fuel line is clogged or leaking. Carb nipple is blocked. There may be more but I'm tired of typing. Start going through the list one by one. Good luck. |
Originally Posted by Tony Corley
(Post 10344872)
Now I'm the first to admit I'm a newbie here, but I was under the impression these thing don't pull fuel by vacuum, but push it by exhaust pressure? Is your tank lid sealed tight? Any exhaust leaks in the header to engine or header to pipe? I'm certain some more experienced people will come on here and clarify
Zkid, are you blowing in the exhaust pressure line and you get fuel to the carb? If so I think first guess would be exhaust seals as it works until the engine is running (ie no exhaust pressure) Jaz's list is good |
thanks guys.
it was running when he got the thing a few weeks ago but now it wont. im going to check exhaust then work through that list |
| All times are GMT -7. It is currently 01:13 PM. |
