O.S. .21 VZB help
O.S. .21 VZB help
I have a .21 vzb with the black block that when i stop and let it idle will hold a high idle and sounds lean but after a few seconds it idles down and no longer sounds lean. I have reset the needles to factory setting and started over and made no difference. I then checked motor, carb, tank, and lines none had an air leak. I am stumped any help would be appreciated.
lean the bottom end i hour at a time till.it idles high constantly then adjust your idle out but you need to get your motor and chassie saturated
let me know how you go
thanks for all the ideas. I have gone over the whole buggy again everything looks good. I checked for leaks again by pluging the intake and exahuast ports the dunking under water while i blow into the fuel line i didnt see any leaks. I changed clutch bell bearings and put a new plug in just to rule them out. I havent got a chance to run it yet due to the weather hoppfully i can run later today. Thanks again for the the help.
Thanks for all the help i put new clutch bell bearings in and changed out the glow plug again to a ofna t4 plug and it runs great and all the problems are gone.
