Wheels just won't stop spinning at idle
#16
There are only a few things that will make the wheels spin at idle:
1) Idle speed too high
2) Clutch springs bad
3) Clutch bearings bad
4) Clutch bell hitting flywheel
5) All the above
5) All the above
#17
Duplicate post!
#18
Your wheels are turning because the clutch is engaging. End bell free play should be 0.5-1.0mm no more then that! Is your motor exactly 90deg to the spur gear, this is very important? If it is at a slight angle, it could be applying side pressure on the bell and forcing it engage with as much freeplay has you have. With the motor out, does the clutch bell spin freely? If your idle is that low, i don't think you have a radio/trim issue, it's with the clutch. Does it make a difference when you first start it as compared to after a few minutes of run time? Also as someone mentioned, does it creep when it's on the ground, or will it sit there? What kind of clutch shoes are you using?
#19
#20
I have an 8ight that does the exact same thing i think.. Lets say after i start it or press the gas and let off the gas the engine revs up when im off the gas and then the wheels spin but then after a couple seconds it goes to a nice idle.. its weird that it revs up like that when im not pressing the throttle. It only does this once and then it idles for forever without the wheels spinning. It doesnt die or anything when i place it on the ground and it runs perfect during a race running at perfect temps.. Its only when i first start it or after i press the throttle. Any ideas?
#22
Thanks for all the feedback. I have ruled out throttle/brake linkage as I have removed the linkage completely from the side carb and it still does it. Given it has only started doing this within the last couple of weeks something has obviously changed. The only thing that I haven't changed is bearings. Shoes, springs, clutch bell - all brand new. I will grab some replacements from the LHS and see if that brings any joy! If this doesn't work I will tear the entire down and start from scratch!
