Engine Crankcase Bearing Tool
I received this tool from SH Engines to try out. I have never seen an easier way to Remove & Install Crancase bearings. The other tool I had did work, but not as good as this one. Another advantage of this one, is it does not use impact to move the bearings. It Installs and removes bearings with threading tools.
It works with 12, 13, & 14mm Crankshaft sizes.
I received this tool from 'HUDY' to try out. I have never seen an easier way to Remove & Install Crancase bearings. The other tool I had did work, but not as good as this one. Another advantage of this one, is it does not use impact to move the bearings. It Installs and removes bearings with threading tools.
http://www.absolutehobbyz.com/produc...oducts_id=2172
