Like Tree3Likes
OS Based engines
Old 08-06-2012, 06:56 PM
  #31
Rsickles's Avatar
Trader Rating: 21 (100%+)
The Arrow P/S is good, but I agree you'd be better off keeping your 5-port sleeve and getting it resized by Ray. That way you can spend the money you saved on an OS brand rod too. You can use the Arrow wrist pin clips (these are G-clips instead of C-clips) and new wrist pin... under $10 for piece of mind.
Rsickles is offline
Old 11-06-2012, 05:17 PM
  #32
carpet Carlos's Avatar
Originally Posted by BrakeTurnAccelerate
The LRP is a XZ-B Speed.
But the lrp zz21cc is ceramic ? I want this engine so bad so if there is a os version witch is it ?
carpet Carlos is offline
Old 11-06-2012, 05:24 PM
  #33
Rsickles's Avatar
Yes, rear bearing ceramic.
http://www.teamassociated.com/lrp/pa...ails/LRP32120/
Rsickles is offline
Old 11-06-2012, 05:28 PM
  #34
Originally Posted by Rsickles
But The xzb doesn't have ceramic crank case or head I'm confused sorry
Old 11-06-2012, 05:34 PM
  #35
Rsickles's Avatar
ZZ.21c and XZ-B Speed are same engine, minus the name/color. Same bore, stroke, timing, etc. Identical internals.
Only difference is the LRP has a fully machined head.
Rsickles is offline
Old 11-06-2012, 05:44 PM
  #36
So xzb is also ceramic ?
Old 11-06-2012, 06:06 PM
  #37
nitroexpress's Avatar
That's what the advertising says. The Speed has a rear ceramic. Standard XZB does not.
•Race-Winning Power Characteristics: A tried and true 3-port sleeve design (3 bypass ports, 1 exhaust), provides smooth, crisp acceleration. This has been achieved through a combination of a specially designed "SPEED" inner head and sleeve porting. Fuel mileage has been improved by 8%*
•Outer Head: The low-gravity, black-anodized outer head features laser engraving and has been heavily machined for improved cooling and extra weight reduction. The overall height is 9mm shorter than the previous model, providing a lower center of gravity and a greater level of stability.
•Carburetor: A newly designed 21J2(B) carburetor includes 6, 6.5, and 7mm aluminum venturi's. Even the smallest 6mm venturi doesn’t affect its easy tuning characteristics.
•Ceramic Ball Bearing: The black anodized crankcase adds a ceramic ball bearing in the rear to reduce rolling resistance.
•Crankshaft: The crank intake passage is silicone ramped for a better fuel mixture flow. A tungsten insert is pressed in the counterweight to optimize inertia mass. DLC coating is applied to minimize frictional loss as well as improve durability and lifespan.
nitroexpress is offline
Old 11-06-2012, 06:13 PM
  #38
But the actual crankcase is aluminum were the zz 21cc is ceramic or am I reading the zz wrong? I might be? if you look at the the parts list the zz21c crankcase is ceramic not just the rear bearing
Old 11-06-2012, 06:14 PM
  #39
Even the head ceramic
Old 11-06-2012, 06:32 PM
  #40
It's called the .21 ceramic not really ceramic ? Right lol sorry guys thanks for the help I'm a little hard headed
Old 11-06-2012, 06:42 PM
  #41
Rsickles's Avatar
It's called ZZ.21c[eramic] because the main rear bearing is ceramic. That's it.
Rsickles is offline
Old 11-06-2012, 07:05 PM
  #42
Ok I ordered the zz21c from ae now I have it and I'm thinking if I have to rebuild I can use parts for a xzb speed sorry I just got into Rc in June and have alot to learn thank you fellas for your help
Old 11-07-2012, 01:45 PM
  #43
I have an OS VZB Tuned ... what temps should this thing be running at? Im always have to re tune the motor.
MBX6-R_LEDFERD is offline
Old 11-07-2012, 02:19 PM
  #44
pickle311's Avatar
Trader Rating: 31 (100%+)
Don't tune to a specific temperature. Tune for performance, sound, and smoke trail. You can have a motor way out of tune and it running it what would be the normal temperature range, seen it and done it in my early days.
pickle311 is offline
Old 05-09-2013, 07:57 PM
  #45
Alexnailey692's Avatar
Originally Posted by Flip it
Going through the engine posts there seems to be a lot of OS based engines that are "rebranded". I have read on here in a lot of posts that engine X is a rebadged speed for around half the price and engine Y is a rebadged Vspec etc.
I know the ninjas B01 and B02 are OS based and the Hara spec engine is based on the speed.What other engines are made for other brands by OS and what do they based on.
The Hara engine isn't that diffrent it only had a diffrent colling head design and decals
Alexnailey692 is offline
