Large issues!!
#17
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
about and 1 1/2 from me.. you are close to brookfield.. about a 30-40 min drive for you.. run down to trackside in brookfield and visit scotty and the boys.. they will help figure things out. plus what every is wrong they should have all the parts there for it.. jeremy
#19
similar issue kept happening to me and wouldn't you know it, one of the brake rods would catch and bind on the center diff mount if I went full throttle preventing its return (Seems I had to hit a bump while it was at full throttle for this to happen). after everything I checked all it took was a simple check of the servo movements on the work bench.
#20
#21
#22
New issue
Spur gear issues, i need the spur gear that comes on the ten-t only metal and the same pitch thats on the 8ight. Anyone know how small of a gear i need to match the ten-t's outer spur diameter? Basically, i need the exact dimensions on the ten-t's spur gear, but the same pitch that is on the 8 scale spurs.
#23
Spur gearz?
Spur gear issues, i need the spur gear that comes on the ten-t only metal and the same pitch thats on the 8ight. Anyone know how small of a gear i need to match the ten-t's outer spur diameter? Basically, i need the exact dimensions on the ten-t's spur gear, but the same pitch that is on the 8 scale spurs, and metal.
