need help with my losi 810
So everything was fine until I decided to tune my engine, the wheels keep spinning and if i turn my idle down any more then where its at it will die on me. the the idle right now sounds perfect i have good throttle response but for some reason it acts like my idle is high and keeps spinning my wheels. Is it the clutch or anything else i can try? thanks.
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
i will move it for you.. jeremy
check for a lean low speed needle setting or a broken clutch spring.. might even be a bad clutch bearing..
