Can an engine with a bad bearing still run perfectly?
#17
Check if your crank pin is out of round with some calipers. If its not then pick up a rod from a tecnopower engine they are compatible with the ole GRP engines I belive. However check for corrosion or looseness of the rear bearing, I have had one that felt good but the car ran like crap till I changed it. However what your symptoms are sounds to be the rod. Previous owner may have had a run-away, or simply lied about engine age.
#19
If its engine noise. Its could be that your conrod bushing or the crank pin are worn. Check also the main bearing for play. These conditions will make the conrod hit wall of the crankcase resulting a loud noise and tuning issues. This happened to my picco(bearing) and grp(conrod).
Also inside the case looked good and I couldn't visually see any hit or wear marks on anything in the engine at all.
#25
I checked the bearings and all seem good. The crank is good. The conrod has a tiny bit of play in it but I'm not 110% sure how much is acceptable in a 2-3 gallon old engine?
New crankpin=5.00mm, replace conrod
Bad crankpin =4.95mm, replace both
#26
#27
the Picco will use the same standard bearings a V-Spec would
#29
I bought this engine used. Is it possible it had sat for so long that the bearings were rusted or gunked up causing engine noise and after I put some fuel through it that they got lubricated and quit making noise?
I just put a whole tank through it and it never once made a noise.....
