Exhaust Coolers....
Old 11-11-2011, 05:38 PM
  #16
Trader Rating: 24 (100%+)
Originally Posted by race2win View Post
true, but i think a lot of us including myself ......lets say a 15 minute main do better in the last 5 to 7 minutes than the first 5 to 7 minutes of the race, there fore pitting early and being able to make the rest of the main in runtime makes a differnce. if i pit on first 2 laps and know i can make it on the last 11-12 minutes (which i normally run better) then it is worth it to pit early and have a 12 minute runtime. make sense?
I get that part, I also have a game plan going into a race and it can change due to ALL the track conditions as well. I can pit early or late. If I'm doing good in the first 1/2 of a race I will push it knowing in the back of my mind that eventually I will need fuel, I keep it real. I most certainly will NOT give credit to a piece of aluminum in-between rubber fuel tube to cool the meager amount of exhaust going into the tank for longer run time That's redonkulous
got_nitro is offline
Old 11-11-2011, 05:41 PM
  #17
Suspended
i respect your opinion! takes a smooth finger to notice a differnce
race2win is offline
Old 11-11-2011, 06:04 PM
  #18
Rsickles's Avatar
Trader Rating: 21 (100%+)
Simple solution to end the debate...
Someone invest the money in a wireless temp probe and stick it in the fuel line about 1/4'' just before the carb inlet needle to measure the temp going into the engine. Do it without a cooler, then cut the fuel line and stick a cooler on, same setup back-to-back.
It's gotta' be worth the $500 in testing to gain those 20 seconds.
Rsickles is offline
Old 11-11-2011, 06:21 PM
  #19
Limywidget's Avatar
I guess I was looking for someone to explain how it cools if the exhaust is static. I don't think I will pick one up because I don't think it is possible for something to be thermodynamically cooled if there is no flow. They do look pretty snazzy though.
Limywidget is offline
Old 11-11-2011, 06:24 PM
  #20
Suspended
to those who are racing for money it may be worth it, but until then i like to keep the racing fun and just a hobby. when the argueing starts is when the hobby begins to be............well....not a hobby
race2win is offline
  #21
beidle99's Avatar
Has anyone felt if the cooler is actually warm to the touch after a tank?
beidle99 is offline
  #22
Better yet, have it part of the TELM. sys, read it on your TQ.
Nah, give me the $500 and I'll run faster & leaner. $500 could get me 10 pinches and a couple of new sleeve's
Old 11-11-2011, 06:28 PM
  #23
Suspended
point given.......you need the 500.00? if you raced pro you might not
race2win is offline
Old 11-11-2011, 06:36 PM
  #24
I'm no pro. Pro's come off the track at 320-330, run so lean they get the extra min. What do they care I could act pro with a extra $500 in the hip...
Old 11-11-2011, 06:39 PM
  #25
Suspended
not as easy as it sounds my friend, just sounds simple
race2win is offline
Old 11-12-2011, 02:47 AM
  #26
lochness42's Avatar
Yes it is and is more than warm One of my mates thought that it can't cool anything so he tried to touch cooler himself after run.
lochness42 is offline
Old 11-12-2011, 06:14 AM
  #27
BlueStreakOne's Avatar
Even simpler. Shoot the temp of the fuel in a near empty tank at the end of good run. Once with a cooler and once without. This is when the cooler would have presumably made the greatest difference. I have not done this but my experience tells me the fuel is cool to the touch either way.
BlueStreakOne is offline
Old 11-12-2011, 06:38 AM
  #28
Please let us know how the testing works out for you. I'll be one of the guys on the stand making 43,000 RPM noise out on the track
Old 11-12-2011, 04:22 PM
  #29
I'm not doing any testing. I wouldn't install one even if it did add 20 seconds. I hate leaks.
We already know it does not change rpms, that fuel does not condense like air due to such slight changes in temperature, that no other form of motor sports relies on chilled fuel to increase performance and that no car or truck being offered today makes claims of increased fuel economy resulting from a fuel cooling feature. I think of fuel line coolers as one of the ultimate rc bs products supported entirely by our addiction to try to build better.
Old 11-15-2011, 04:51 PM
  #30
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
really?
http://www.summitracing.com/search/P.../Fuel-Coolers/
http://www.flex-a-lite.com/auto/html/fuel-coolers.html
http://www.f1technical.net/forum/vie....php?f=3&t=445
R/C Lidz is offline
