Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
BuKu Speed Tune Clutch & RC Performance Products >
Like Tree22Likes
Old 11-18-2015, 07:45 AM
  #1636
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by inpuressa View Post
Thanks for the pic and info guys
It wasn't as offset as I thought it would be.
Thinking of trying the bearing cover in the future so I wanted to get the normal one.
As mentioned above, when cap is added the flywheel gets even closer to chassis. So def start with the mugen style. Every mm counts at that point. When running Mugen, we filed the chassis slot a bit for more clearance. It sounds horrible, but as phillyjynx pointed out, the Kyosho slot is way bigger than Mugen. So we felt comfortable doing this. We never had an issue
rallyebmx is offline
Old 11-22-2015, 08:46 PM
  #1637
mourinho's Avatar
Trader Rating: 46 (100%+)
what size is the little imperial Allen wrench that comes with these clutches? I've lost mine and would prefer to get a proper driver as a replacement.
mourinho is offline
Old 11-22-2015, 10:27 PM
  #1638
rallyebmx's Avatar
1/16
Old 11-22-2015, 11:43 PM
  #1639
mourinho's Avatar
Originally Posted by rallyebmx View Post
1/16
mourinho is offline
Old 11-23-2015, 12:37 AM
  #1640
fyrstormer's Avatar
Just to put in my 2 cents: This clutch is a huge improvement on the T-Maxx Classic. The adjustable engagement points mean it's possible to set the clutch so it's only lightly engaged when it reaches the RPM that engages the fwd/rev pawls inside the transmission, so the transmission doesn't bog-down the engine the instant those pawls engage. This means the T-Maxx Classic no longer stutters as it starts to move. It's worth every cent of the $50 it costs to buy one.
fyrstormer is offline
Old 11-23-2015, 08:52 AM
  #1641
Suspended
Trader Rating: 61 (100%+)
Socket is offline
Old 12-02-2015, 12:11 PM
  #1642
Suspended
Anyone running the brass flywheel?
Socket is offline
Old 12-02-2015, 08:51 PM
  #1643
Hey Socket,
I run the brass flywheel on both my Alpha .23's in my truggys and on my Alpha Dragon in my Mbx7r. I tend to be trigger happy so it helps me with those powerful engines. And I only run the Komposite shoes, gotta love the mirror finish on the inside of the clutch bell. And the infinite adjustment of the clutch springs.
Cheers
Brian
Crash Test Dumy is offline
Old 12-02-2015, 09:48 PM
  #1644
Suspended
Originally Posted by Crash Test Dumy View Post
Hey Socket,
Cheers
Brian
With the current track, I right now have a massive power surplus, and feel the same right now. Kicking around the idea of trying it.
Socket is offline
Old 12-03-2015, 08:12 AM
  #1645
Retired09's Avatar
Joe. I use brass on slippery tracks..............
Retired09 is offline
Old 12-13-2015, 12:54 PM
  #1646
THE PHILLY JYNX's Avatar
Default COMING SOON!!
Attached Thumbnails BuKu Speed Tune Clutch & RC Performance Products-4-shoe.jpg
THE PHILLY JYNX is offline
Old 12-13-2015, 03:34 PM
  #1647
BlueStreakOne's Avatar
Very cool.
BlueStreakOne is offline
Old 12-13-2015, 04:47 PM
  #1648
Suspended
Originally Posted by THE PHILLY JYNX View Post
I heard about this...
Can't wait to try it.
Socket is offline
Old 12-14-2015, 07:40 AM
  #1649
fyrstormer's Avatar
Under what circumstances would one choose a four-shoe clutch instead of a standard 3-shoe clutch?
Old 12-15-2015, 01:35 AM
  #1650
Can't wait to try a four shoe Buku!
I would guess the four shoe would be better at keeping the clutch bell aligned if u set your stagger to have one set of opposing shoes open at the same time and later the other set. Having said that I've never had a problem with each shoe of the three shoe clutch opening at different times.
My ST-RR EVO is offline
