Originally Posted by Honu
(Post 9797742)
How many watts does the 120v Deuce consume. I'm planning to use it with my generator.
Unregulated voltage from lesser made genset units will cause unit to heat too rapidly so pay attention to that , honda , yamaha and other quality brands are regulated so no issues |
How much mah I need to heat the engine. Our ambient temps are always above 86F. Trying to get the required lipo. Also will low discharge be sufficient (20C)?
Originally Posted by rcindia
(Post 12556749)
It's wise to use a voltage alarm or voltage cut-off for Lipo batteries. Yes, 20c is more than enough. The unit only draws 5 amps. On a 5000mA battery this is only 1c. |
| All times are GMT -7. It is currently 12:59 PM. |
