Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
OS 28xz Crankcase alternative Ninja ?? >
Old 10-01-2011, 04:20 PM
Trader Rating: 22 (100%+)
Default OS 28xz Crankcase alternative Ninja ??
Could someone tell me if a 28 Ninja case is the same as the 28xz OS. I need to be 100%, porting and all. I have a cracked case and checking into alternative options.
Landmines is offline
Old 10-01-2011, 04:43 PM
Maximo's Avatar
a Ninja 21 case will not work...the sleeve has a much different outer diamter
Maximo is offline
Old 10-01-2011, 04:45 PM
Suspended
Trader Rating: 202 (96%+)
Why not just get the OS case? they dont make the ninja .28 any longer.
http://www3.towerhobbies.com/cgi-bin...ssing%20Data**
inferno13 is offline
Old 10-01-2011, 05:03 PM
Ninja 28 not 21
I have a buddy who has a Ninja 28 that I can get. He's in another state so I don't have it to compare. I don't have a problem finding a new block. Who wants to spend $120 if they don't have to?
Old 10-01-2011, 05:04 PM
The .28 ninja engine was made by grp and has nothing to do with the O.S engine.. So u cant use O.S parts on this engine.
JanE is offline
CKmaxx's Avatar
And the Ninja 28 was from the MR line of engines aka GRP, Technopower, TQ. Not compatible with the OS or JX line of motors.
CKmaxx is offline
Old 10-01-2011, 05:09 PM
CKmaxx's Avatar
Looky what I found.....
https://www.ssl-stormerhobbies.com/c...pl?pn=LOSR2027
CKmaxx is offline
Old 10-01-2011, 05:28 PM
Thanks guys. Sure saved me some time. I don't have a clue exactly what those Ninja 28 cases even looked like. I was told it might work. But there again, he runs Ninja and doesn't know about the O.S. parts.
I may have to just break down and get a new one. 2nd cracked case in a month but wouldn't run anything else.
Thanks again.
Old 10-01-2011, 06:37 PM
RMKinWI's Avatar
Trader Rating: 15 (100%+)
I have a used OS 28 case that I'll sell you for $40 shipped or $60 for complete engine minus carb. The crank pin is worn out, but everything else is good.
RMKinWI is offline
Old 10-19-2011, 11:30 PM
Default OS 21vz-b v spec 2 worlds engine
I have a OS 21vz-b v spec 2 worlds engine it has a cracked block and i can buy one new. I know of some second hand os blocks i was thinking of trying. Does anyone know weather any are simialar. The part number for mine is 23751030. Any help would be apreciated.
Thanks.
benando is offline
Old 10-20-2011, 07:09 AM
motomatt's Avatar
Thanks again.
I'd guess something's wrong if you've had two crankcases crack in such a short period of time. Check your chassis for bend or tweak. Also the chassis braces should be secure. Maybe the engine is situated too close to the chassis. Over bumps and jumps the chassis flexes, which could cause the engine to hit the chassis. Are there any marks that would confirm this on the chassis at the engine area?
motomatt is offline
