Braking shuts off engine? / Idle speed needle does nothing?
Whenever I start my truck, I'll drive it for a bit (it also seems sluggish), but whenever I brake, the car shuts off.
Which brings me to my second problem, when I try to fix it using the idle speed needle, the needle doesn't do anything.
HALP
HALP
clutch spring broke or clutch bearings are locked up. If these aren't in good shape, they will cause drag and pull the idle down.
Now when you fix this area, be prepared to re-tune your engine - idle, low and high speed needles...
You broke your idle stop screw... Back it all the way out and look at it... Does it look like this one here???
Only fix is to take the slide out of the carb to remove the broken part of the screw and then replace the whole idle stop screw...
FYI if the cause of a broken idle stop screw is when you twist the carb ball when you are installing/removing your throttle linkage... Probably happened the last time you pulled the engine.
