Braking shuts off engine? / Idle speed needle does nothing?
#31
Here is a link to a reedy carb. click on the it to get the zoomed in pic. Now in the pic u will see the Idle screw to the side of the carb at a angel, make sure u are turning a screw that is in a similar place. HSN is at the fuel inlet, the Mid range needle is just below it,( If it is equipped with one) at the opposite end of the slide and the LSN is at the end of the slide( throttle linkage).
Just make sure u are adjusting the right needles first.
http://www.amainhobbies.com/product_...ete-Carburetor
#32
I'll agree with some of the posts that referred to throttle linkage issues....
Now i'm not saying you did anything wrong but some times if the trim isn't set right the servo could in fact close the carb...granted or i assume you probably have at least a paper clip width opening you should be all hunky-dory.
So you should be all good there....and peeps who are saying its the clutch are wrong....if the springs were broken it would affect anything but forward movement.
Sigh....carbs are like women...high maintenance but once you find the sweet spot....she purrrsss.
#33
reset the carb to .5mm with the insert out. Put the insert back in. Hook the linkage up to the carb, turn on the buggy and radio with the buggy not running. Hit the brakes and see if the slide is closing. If its moving when hitting the brakes then adjust the collars on the linkage. If it is more than likely its the collar on the outside controlling the throttle. Lossen the collar to relive the pressure tighten the collar when the throttle is closed. Kind of hard to explain with just words
