Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Help my engine takes for ever to build up power >
Old 05-22-2011, 09:56 PM
Default Help my engine takes for ever to build up power
I have an axial .28 rr2 and it does not have good power on the low end, it takes long to accelerate, i was told it may be air leak, could any one help me.
Thank you
Andresm74 is offline
Old 05-23-2011, 10:08 AM
no1rick's Avatar
Thank you
Yes, an air leak is one of many possibilities, and should be investigated thoroughly. make sure you have a good seal between the carb and base of the motor, use a little silicone sealer if necessary.
First make sure your gearing isn't too high, also that the drivetrain, and front wheels of a 2 wheel dr aren't binding.
Go back to factory defaults on the needle settings, you have three different ones, then, following tuning procedures, make the adjustments.
Here are a few handy links for you
http://axialracing.com/wordpress/tag/engine-tuning/
http://www.axialracing.com/ftp/engines/techtips.html
no1rick is offline
Old 05-23-2011, 05:52 PM
Thank you for your help
Old 05-24-2011, 04:15 PM
Laguna Blue's Avatar
Seal up the carb as previously mentioned with some clear silicone. Also maybe drop a tooth on your clutch bell.
Laguna Blue is offline
Old 05-24-2011, 04:36 PM
sriley's Avatar
Trader Rating: 32 (100%+)
Clutch springs. Make sure you don't have too soft springs.
sriley is offline
