Kyosho Gxr.18 issues
Old 05-16-2011, 06:42 AM
Default Kyosho Gxr.18 issues
hi all, been having a few issues of recent with my GXR motor, it seems to start (normally first pull) then can idle but as soon as i attempt to accelerate the engine either stalls, or trys to pull off but barely gets the buggy to a crawl.
have already attempted changing the needle settings, cleaning the carb, different air filter, different fuel. and engine had a new piston and sleeve about half a gallow of fuel ago.
seems to me that the engine isnt getting enough air to run properly as when the tank was near empty it managed to rev up properly but no matter the needle settings on the carb this doesnt change?
also got the problem that two screws holding the cooling head on have jammed tight as has the one holding the clutch bell, any ideas?
thanks
olicool11 is offline
Old 05-21-2011, 01:22 PM
Bump, still no replies, could really do with some advice here if somebody knows what is going on?
