Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Engine issues-Help needed please! >
Old 05-09-2011, 01:05 AM
Trader Rating: 65 (100%+)
Questions?? Engine issues-Help needed please!
Greetings-
I'm still having issues with my new Axial .28 s2 engine. Here's the problem. After I give the engine some throttle (vehicle moving around) where its now at idle ...the rpm's shoot up. Where the engine sounds like its full throttle and wants to "move". At this point I shut it down. So, in a nut shell the idle changes after giving it throttle at a resting position. I'm lost...I've even tried a different carb...guess what? It did the same thing. Any help would be great. What the hell would cause this? Also, when it wants to "race off" the barrel gap on the carb doesn't move! Meaning its at the resting 1mm gap position and yet the engine rpms jump through the run and the vehicle moves
PS- Im still in the break in phase of this engine. Only around 3 tanks. I've sealed the engine for airleaks. I've checked to see if the servo's where bad. Not the problem. Also, this engine runs very very hot. around 260-290 atm. I've got the engine rich atm.
nrm1977 is offline
Old 05-09-2011, 01:42 AM
808gx7r's Avatar
Originally Posted by nrm1977 View Post
Greetings-
sounds like a lean LSN, check your fuel lines first.
808gx7r is offline
Old 05-09-2011, 01:51 AM
Hello- I've replaced the fuel line. Someone told me that it sounds like LSN is too lean BUT, ive got huge amounts of smoke coming out. As I'm running the engine pretty rich due to break in. The LSN isn't leaned out atm.
nrm1977 is offline
Old 05-09-2011, 02:57 AM
808gx7r's Avatar
you can still have a rich setting on hsn when lean on bottom. lower the idle needle to .7 aswell
808gx7r is offline
