Werks b5 questions
Old 05-01-2011, 05:33 PM
pl_unc86's Avatar
Trader Rating: 17 (100%+)
Default Werks b5 questions
I noticed that i have some fuel leak out of the front bearing behind the flywheel. Is this normal? This is not a large amount of fuel, but just enough for me to notice because of dirt being stuck around the flywheel area. I know its not fuel from the tank because its very clear that its coming directly behind the flywheel.
THanks!
pl_unc86 is offline
Old 05-01-2011, 06:56 PM
R/C Lidz's Avatar
Trader Rating: 55 (100%+)
hey noob
I haven't ran a B5 *yet*, but I have heard others mentioning this on a young motor. Once you get a race tune on there and lean it up a bit it shouldn't leak anymore.
If you have any problems get a hold of Brian or Bellman, they both run 'em.
R/C Lidz is offline
Old 05-01-2011, 07:20 PM
pl_unc86's Avatar
Thanks Josh!
How have you been man?
pl_unc86 is offline
Old 05-01-2011, 07:31 PM
MotoGod's Avatar
Trader Rating: 118 (100%+)
Yeah Peyton....once you get the race tune down that should go away for ya. Just rich is all...
MotoGod is offline
Old 05-02-2011, 12:58 AM
THanks!
I run a Clocked B6, same thing. Stopped weeping from the front bearing after about the first 1.5 tanks. So nothing to worry about, I'd say it's normal.
John. is offline
Old 05-04-2011, 09:13 AM
Rcrenew's Avatar
+1 These guys are right. If it tuned rich you will get some front bearing seapage from the excess oil. If you are fully raced tuned and running at optimum temps and the front bearing leaks badly then replace the bearing. But in most cases a small amount of seapage is normal.
Lance
Rcrenew.com
Rcrenew is offline
