Fuel economy??
Old 04-25-2011, 09:18 AM
Default Fuel economy??
Ok so I had my sights on getting the hyper 7 with .21 and 8 port engine, but I found the Ofna mbx comp that has .26 engine. Now I'm kind of confused as to which one I should get. It will be a bashing buggy only
So my question is, will the fuel economy of the .26 be considerably worse than the .21 How is the .26 fuel economy in comparison to a .28
Thanks!
Bo0m UR DEAD is offline
Old 04-25-2011, 05:28 PM
The .26 vs the .21 will be like comparing a 20mpg car to a 35mpg can and the same for the .28 vs the .26.
And don't even bother with the .28, it is just too much power even for a basher.
I would not go bigger than the .26.
Nick411 is offline
Old 04-25-2011, 05:35 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
Thanks!
think 4cylinder mustang to Corvette LS9 : )
losi_racer is offline
Old 04-25-2011, 08:19 PM
So a .26 is a gas guzzler too, huh?
Is there a noticeable difference between the .21 8 port vs the .21 3 port?
Old 04-25-2011, 08:46 PM
ScottyM's Avatar
Trader Rating: 27 (100%+)
If your bashing Fuel economy should not be an issue.. an 8 port is going to get worse mileage then the 3 port..
ScottyM is offline
Old 04-25-2011, 09:01 PM
Oops sorry I meant performance wise is there a significant difference between the 3 and 8 ports?
Old 04-25-2011, 09:08 PM
ScottyM's Avatar
It depends on the engines being compared. An OS V-Spec, which is a 3 port, will out perform that Hyper .21 in almost every way.. IE more info is needed.
ScottyM is offline
Old 04-26-2011, 06:15 AM
Hyper .21 3 port vs Hyper .21 8 port
Old 04-26-2011, 06:20 AM
Roelof's Avatar
With this mentioned I wonder why you want fuel economy. As a basher you want all the power and speed you can.....
Roelof is offline
