os speed vz tune
right i have read the engine tune bible and it does sort of cover my question.But when i rev the engine when i let go of the throttle it seems to have two idles. High idle for about five to ten seconds then settles to a normal idle is this normal cant seem to get rid
idle gap is to big.
how about a pause inbetween full pulls?? it revs then pauses and revs again? zoom...zoooommm
Originally Posted by RockStar_199
(Post 8968995)
sorry im asking for a fix lol my engines seem to do this alot and i have to fat the bottom to fix but yet not the tun im looking for on the bottom
Sounds like the low end needle is too fat.
Lean the low end needle a bit more till the idle stays high after a WOT pass. Then turn down the idle with the idle screw. When your idle is consistent check you high speed needle. It might need richening up a little bit after this. Edit: If you mean stuttering / machinegunning when your talking about a high idle after WOT then your low end needle is too lean (possibly high end needle aswell): richen it up a bit. |
Originally Posted by Ambros303
(Post 8969228)
yes bottom too fat idle too high solved it cool guys thanks for the help
