Glow plug question
Old 03-31-2011, 09:23 PM
Trader Rating: 17 (95%+)
Default Glow plug question
are the tapers on the OS plugs different then the O'donnell? I have a Jammin .28 if they are different can I use O'donnell on this engine thanks
koreanassasom is offline
Old 03-31-2011, 09:26 PM
J.Sears's Avatar
I've used both plugs and never had any issues with them leaking or anything like that if that's what your wanting to know.
J.Sears is offline
Old 03-31-2011, 09:28 PM
Suspended
Trader Rating: 202 (96%+)
+1, same here with no problems
inferno13 is offline
Old 03-31-2011, 09:37 PM
thanks guys must have read something wrong a while back
Old 03-31-2011, 09:41 PM
jmaxey51's Avatar
i wouldnt use OD plugs in jammin engines, it wont run right, OS P4 is the way too go... or picco plugs are best.... the jammin engine is the only engine i wont run OD plugs in, i run OD plugs in all my engines except for the jammin engines...
jmaxey51 is offline
Old 03-31-2011, 10:43 PM
Maximo's Avatar
sometimes they leak, sometimes they don't..... IMO the best bet is to run either Picco or Werk's plugs...
Maximo is offline
