Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
cant find a bearing that doesnt leak!!!! >
Old 03-28-2011, 08:18 PM
lanmine657's Avatar
Default cant find a bearing that doesnt leak!!!!
i am looking for some input for a front engine replacement, I would like to get more than few gallons before it starts leakn because i am spending more on bearings than the motor is worth. Any bearings out there that wont break the bank but last as long as the motor?
lanmine657 is offline
Old 03-28-2011, 08:21 PM
j_blaze14's Avatar
Trader Rating: 34 (100%+)
double sealed avids have worked for me. what brand are you using now? how is the case, worn?
j_blaze14 is offline
Old 03-28-2011, 08:24 PM
houston's Avatar
Trader Rating: 96 (100%+)
17011 from novarossi
houston is offline
Old 03-28-2011, 08:32 PM
Toiffel's Avatar
Trader Rating: 52 (100%+)
Are you sure it's just not that it's a tad too rich on the bottom? To be honest, the only time I've encountered a leaky front bearing is from a bad LSN tune, not to say that you might have a bad bearing, but if it's a problem some what too often, I would start looking at a different cause....just a thought...
Toiffel is offline
Old 03-28-2011, 08:34 PM
houston's Avatar
That is absolutely correct
houston is offline
Old 03-28-2011, 09:44 PM
lanmine657's Avatar
very very possible, didnt know the two could be related
Old 03-28-2011, 11:04 PM
Default re
esp if fuel has a high oil content
toofless is offline
Old 03-29-2011, 12:19 AM
am
The seal for the front bearing is not in the bearing itself, but in the clearence between crankshaft and engine block. If this clearance is to big your bearings will leak either way you do it.
If you have a "few" gallons between each timem you change your bearing i would say it is pretty normal. remember that you are running a offraod engine with alot of dust. No bearings are compleatly sealed, if they had been, your engine would not perform very good as the friction on the seals would be very high.
best engine bearing you can buy is the 17011 as Huston says. This bearing has doubble seals in the front of the bearing..
am is offline
Old 03-29-2011, 02:16 AM
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
17011 from novarossi As Monty suggested,
Or you can try the Reedy one. Even Monty liked that one.
Teufel Racing is offline
Old 03-29-2011, 07:37 AM
houston's Avatar
Hey hey hey now !
It wasnt bad though, lots of resistance but good seal
houston is offline
Old 03-29-2011, 01:17 PM
jpalessi's Avatar
Trader Rating: 55 (100%+)
+1
most common tuning mistake.
high idle
FAT bottom
lean high speed.
jpalessi is offline
Old 03-29-2011, 07:33 PM
Sorry Monty,
Didn't think about the resistance part though there are many to choose from. LOL. Gues I should have said you liked it a little, though I like the Rossi one a little better.
Old 03-29-2011, 08:42 PM
houston's Avatar
Sorry Monty,
its all good James!!
houston is offline
