Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
If you know Novarossi help me out >
Old 03-21-2011, 07:11 PM
HarleyGuy's Avatar
Trader Rating: 16 (100%+)
Default If you know Novarossi help me out
I bought a new Novarossi a few months ago and I'm just now putting it in my buggy, the issue is I can't gut a clear idea of which engine it is... I know I could look one the box but alas right now I'm about 1000 miles from home and that's where the box is.
The engine I have is a Plus 21-4 that much I know... The issue I have is mine has a big T next to the plus sign... This would make me think it's a Plus 21-4T however under where it says NOVAROSSI it says TUNED (not FACTORY TUNED, just TUNED)... So is it a Plus 4 buggy, a Plus 21-4T (these are the only two options I found on Nova's website.... Or could this simply be an older model or a custom job?
Help me out please,
Shane
HarleyGuy is offline
Old 03-21-2011, 07:39 PM
houston's Avatar
Trader Rating: 96 (100%+)
Its exactly what it says plus 21-4t
No ceramic rear bearing is about the only difference between that and the 21-4c
not a team
houston is offline
Old 03-21-2011, 07:42 PM
Jaz240's Avatar
Trader Rating: 52 (100%+)
Very Nice engine by the way. One of the best buggy engines of all time!
Jaz240 is offline
Old 03-21-2011, 07:46 PM
tony montana's Avatar
Trader Rating: 73 (100%+)
I have the 2010 team edition and loving it so far
tony montana is offline
Old 03-21-2011, 07:50 PM
JANKEII's Avatar
The BEST... Mine is still running strong. It had 8 gal with nothing done to it. Now with a repinch and 3 gal still running strong...
JANKEII is offline
Old 03-21-2011, 07:57 PM
HarleyGuy's Avatar
not a team
So are all plus 21-4t's tuned? I was just confused because in all my searching on the net I couldn't find another picture of one with TUNED on the head like mine... Just wondering.
Thanks,
Old 03-21-2011, 08:01 PM
HarleyGuy's Avatar
Now that we know what it is... what's the best way to break it it? I have already run two tanks through it at idle. Before starting I heated the engine up to ~200F with my heat gun. The issue I had was that I could not keep the heat in it and the stock plug simply would not idle at all, so I had to swap it out for a P3 and then it idled but only just.
Any help, again, would be appreciated.
Old 03-21-2011, 08:15 PM
ScottyM's Avatar
Trader Rating: 27 (100%+)
Keep the heat on it and/or wrap the head with a sock, foil, or wrist band. That will keep the heat in it.. Use your remote to keep the "idle" high enough to keep it running.. Most all engines are set so rich out of the box they don't wanna run but ya gotta keep em rich for a while..
ScottyM is offline
Old 03-21-2011, 08:24 PM
houston's Avatar
Keep the head covered and don't be afraid to turn the needles
houston is offline
Old 03-21-2011, 08:25 PM
HarleyGuy's Avatar
Thanks,
I think I'm going to get a Competition Heat as well.
Old 03-21-2011, 09:07 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
you will need to lean the bottom a tad and bump the idle What i did to keep the heat in was take an old open cell truggy foam, put it on the head then pinched the extra together and put a zip tie so it would stay tight on the head.
also you need to be careful with the head button now. OS and Nova have a different taper plug and with you putting an os plug they button may not seal just right now
losi_racer is offline
Old 03-21-2011, 11:13 PM
houston's Avatar
Thanks,
wise choice
houston is offline
Old 03-21-2011, 11:18 PM
houston's Avatar
Thanks,
yes they are
and arent these standard plug ? the ones i got on the shelf are
houston is offline
Old 03-23-2011, 07:51 PM
HarleyGuy's Avatar
yes they are
Mine had a Turbo plug in it... I replaced the stock plug with a Ninja P3 UltraHot and it idled a little better. I also leaned it out (just a tad) so that it would keep an idle. When I get home from traveling (be home on Saturday) I'm going to run a few more tanks through it... Hopefully my Competition Heat will be there by then...
Old 03-23-2011, 08:12 PM
houston's Avatar
intersting , somone must have changed it before you got it i spose
houston is offline
