O'Donnell plugs on sale
Old 03-21-2011, 10:10 AM
  #16
jpalessi's Avatar
Trader Rating: 55 (100%+)
Originally Posted by rider313 View Post
Thanks for the heads up JP
No problem.
jpalessi is offline
Old 03-21-2011, 10:33 AM
  #17
Stubbs's Avatar
Trader Rating: 57 (100%+)
Originally Posted by FLHX1550 View Post
The OD97T is pretty much the best fit for most .21 and larger Turbo applications.
If running 30% or more Nitro, you can switch to the 87T, which was new last year, supposed to be for "high nitro content", but I have used both and can find no measurabl difference
I am actually on the Hobbico Team, and have been told the Z01 is going to be built directly and distributed by O'donnell themselves, but Hobbico has all intensions on carrying the part numbers and products that O'donnell makes.
That is correct. Steve O. is going the same direction as Kyosho, and will be distributing the product line in-house. I'm not sure how the misc. other items (parts, plugs, apparel, etc...) will be handled.
Stubbs is offline
Old 03-21-2011, 10:42 AM
  #18
houston's Avatar
Trader Rating: 95 (100%+)
I haven't had any issues with odonnell plugs in my novarossi engines, odonnell uses the same design as novarossi, could be why
houston is offline
Old 03-21-2011, 11:08 AM
  #19
jpalessi's Avatar
look at the picture. take notice to the threads.
jpalessi is offline
Old 03-21-2011, 03:13 PM
  #20
AlanHall's Avatar
Trader Rating: 43 (100%+)
What's the average life span if a od97? I've been running them and seem to only get a day out of one. As soon as I feel like im having to mess with my tune, I pull it and it barly glows. I have never had a flame out and I don't really run my motor rich at all.
AlanHall is offline
Old 03-21-2011, 03:38 PM
  #21
jmaxey51's Avatar
i can go a few races with them. 87T dont seem to last as long as 97T.... also if you stop your engine by plugging the exhaust, it seems to pop them more often, seen people burning them and thats how they stop theirs, i always stop mine with the flywheel.
jmaxey51 is offline
Old 03-21-2011, 04:23 PM
  #22
houston's Avatar
1/2-3/4 gallon is about the time 97t plugs should be changed if you stop your engine by the flywheel
btw , the plug on the right looks like it just came out of the engine and the one on the left looks as if it has been cleaned just sayin'
on another note , that is exactly what happens when you use the long taper plug after using a short OS style taper in your turbo combustion chamber
houston is offline
Old 03-21-2011, 04:46 PM
  #23
AlanHall's Avatar
1/2 gallon. I guess that's about right for what I've been seeing. I thought I got a bit more from a p3
AlanHall is offline
Old 03-21-2011, 11:39 PM
  #24
houston's Avatar
you can probably get a littl emore fuel through them but why push it
the p3 should last a while , they cost much more and have a much smaller orifice surrounding the filament
houston is offline
Old 03-22-2011, 12:06 AM
  #25
Sein's Avatar
Man I am just lucky, I have had 2 gallons on my current 97t and it still glows bright red when I put the igniter on it. I'm gonna run it till it goes out; or till it starts to get dim when I check it at the end of each day I run.
Sein is offline
Old 03-22-2011, 06:50 AM
  #26
AlanHall's Avatar
Is having the smaller orifice a bad thing? They are I think $2-3 more than the 97 at the lbs. But I can't recall the life I saw.. would of been well into my 2nd gallon including my break in time. That was the 1st plug I used and then tried the 97. I thought about Trying the o2 again to see if it effects run time or performance now that I got a good feel for my engine
AlanHall is offline
Old 03-22-2011, 09:24 AM
  #27
Lille-bror's Avatar
The OD 77T I used during break in on my HPI engine, are still in great shape. +1 gallon until now.
Lille-bror is offline
Old 03-22-2011, 11:40 AM
  #28
jmaxey51's Avatar
i had issues with OS P3 breaking the coils after about half gallon...or just didnt last as long as 97T, and plus i have better power with the colder plug. but the P4, ive had zero issues and still use that plug in my back up engine, 1-2 gallon old P4 in it now.
jmaxey51 is offline
Old 03-25-2011, 10:42 AM
  #29
Lille-bror's Avatar
Just got my 77t plugs from Tower. They are 100% identical with the 77t plugs I bought last year from Amain. Fits e.g. a Novarossi head perfectly
Old 03-25-2011, 02:44 PM
  #30
phaqu22's Avatar
Trader Rating: 31 (100%+)
Just made my order!
phaqu22 is offline
