Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Novarossi 21 - 4C Team or Plus 21 4BTT >
Old 03-14-2011, 03:26 PM
Default Novarossi 21 - 4C Team or Plus 21 4BTT
Hi all
I have just got myself a losi eight Buggy 2.0 and require to get an engine
I do not know which of the two I should get. The older 21 4C team engine which is now dicounted or the new version the Plus 21 4Btt.
Would u notice a performance diffrence between the 2.
Exhaust recomendations would be of help also
cheers
Chreggan
Chreggan is offline
Old 03-14-2011, 09:12 PM
PowerHouse's Avatar
Trader Rating: 66 (100%+)
Originally Posted by Chreggan View Post
Hi all
cheers
Chreggan
Don't be fooled by the hype. The engines are of the same family so they will perform very close and probably so close you won't be able to tell the difference. The timing, engine layout and internal components are interchangable. The only main thing they did was put a new head on it and one version has ceramic balls in the front bearing. If you can get a good deal on the 2010 version, go for it. I still run the 2010 stuff as the new stuff is the same thing with a new look. I would stay with the 9901ss/41021 combo with either Plus 4 version you choose.
PowerHouse is offline
Old 03-14-2011, 10:25 PM
houston's Avatar
Trader Rating: 96 (100%+)
have you seen the new sleeve design?
the exhaust is quite a bit different than the older version , not saying that it is a "whole new" engine but that exhaust will make a bit of difference . i will agree with the pipe for buggy , 9853ss or 2084ss for truggy
houston is offline
Old 03-14-2011, 11:59 PM
andre lim's Avatar
Trader Rating: 58 (100%+)
Wat the diff between Plus 21 - 4BTTS and the Plus 21 - 4BTT
andre lim is offline
Old 03-15-2011, 02:45 AM
am
Only difference is the S version has a ceramic front bearing.
am is offline
Old 03-15-2011, 05:59 AM
I ran the new 21-4BTTS this past weekend.. all i have to say is WOW.. It runs different that the 21-4C team. more top end, more overall power but very easy to control. The best pipe for it is the 2084. I was using a 6mm insert and the new odonnell speed blend fuel. After 10 minutes of running i had almost half a tank of fuel. in the main we went 12 minutes on a tank and i still could have gone another minute or so.
Chad Phillips is offline
Old 03-15-2011, 06:24 AM
Rom
Hi,
New engines are not here to replace any previous ones. These are new engines and old ones are also in 2011 engine line and they are not discontinued nor should be discounted anywhere.
When it comes to Toro Nero then these are now replaced by engines that go by name Bonito.
BONITO.21-7XLB
BONITO.21-7XLBS
So new engines in plus 21-4 engine line are:
PLUS 21-4BTT
PLUS 21-4BTTS
New or updated features/modifications:
- New cooling head design
- Modified cylinder to improve fuel consumption
- New modified sleeve
- Some modifications on crankcase
- BTT has rear ceramic balls in bearing and BTTS has both bearings with ceramic balls
- Modified back plate design
cheers
Rom is offline
Old 03-15-2011, 04:22 PM
PowerHouse's Avatar
The exhaust is shaped a little differently from the 4C Team but in order to compensate for the added width of the upper corners of the port area, the lower and mid portion of the port needed to be narrowed as not to exceed the maximum port width/area ratio needed. In lamens terms, the port window needed to be reshaped so the piston wouldn't rock inside the port and create added stress and pre-mature wear to the piston crown. The exhaust surface areas are very very close so as far as the BTT breathing harder than the 4C, they will run very close.
As far as everything else, it pretty much remains the same. The steel ring in the backplate for reduced rod wear is nothing new nor warranted. The rod does walk a little on the pin during operation but nothing so major that requires something to be done on the back plate. The rod bushing wears out long before the rod brushing the backplate from time to time will have any detrimental effects.
Don't get me wrong, the BTT is and will be an awesome engine to have. I am mostly just telling people not to get all flustered with the new engine because there are still alot of people who wish they can afford the $400+ mill and simply can't and I just wanted them to know not to get discouraged as the Plus4 Buggy, 4C and 4C Team will still be very very competative stock or modified against the BTT in overall power delivery and fuel mileage. I have guys getting 11-12 minutes with the stock Plus4's so hearing the BTT in the 11-12 minute club should be no surprise nor some incredible feat. There are other models from Novarossi and other brands that will compare to those numbers.
Old 03-15-2011, 05:32 PM
aussies1129's Avatar
Trader Rating: 74 (100%+)
I have seen the +4 teams for around 300 so if you can get one at that save your self some cash but sometimes like me I find it hard not to think that the newest is always the best, one side of the mind is beating up the other as its hard to convince the mind into saying that I dont always need the newest best thing out there especially when there is a fair bit of a price difference and the performance is not that far off anyway.
good luck with it
aussies1129 is offline
Old 03-16-2011, 01:03 PM
MBX5TR's Avatar
the only engine that has been discontinued is the toro nero all the other engines are still available but as Chad mentioned the new btt engine is very different from the C team edition in every aspect any one of them is a good choice but if money is not a problem i would get the plus 4 btts with my eyes closed
MBX5TR is offline
Old 03-16-2011, 02:48 PM
Hi all thanks for the replys,
I have ordered the 4btt engine,
Chreggan
Chreggan is offline
Old 03-22-2011, 08:46 AM
Wenbiao's Avatar
Houston, is heat cycle recommended for breaking in the btts ? and can we replaced the fitted plug with OS P3 ?
Wenbiao is offline
Old 03-22-2011, 11:47 AM
PinoyCali's Avatar
Default Pipe for truggy
Hello all,
Is btt good for truggy? And what pipe combo?
Thanks...
PinoyCali is offline
Old 03-22-2011, 12:47 PM
Originally Posted by PinoyCali View Post
Hello all,
Thanks...
get the bonito for truggy.. im running BTTS in buggy with 2084 pipe and 6mm restrictor. runtime is over 13 minutes.. temps range from 260-270
Old 08-12-2011, 10:32 AM
alport78's Avatar
I recently bought 21-4c team and need pipe for that , will dynamite 053 a proper choice, I'm a little short on budget for 9901/21. And which plug for high humidity and around 90 degree ambiance temp.
alport78 is offline
