Vacuum sealing your engine
Old 03-06-2011, 12:44 AM
MaTt 93's Avatar
Default Vacuum sealing your engine
Hi again,
Sorry about all these questions lately but my mum has one of those food saver vacuum sealing things, and i was thinking about putting some after run in my spare engine and vacuum sealing it because im probably not going to use it for awhile. Is it worth doing or am i better off just filling the holes with bits of rag?
Thanks again,
Matt
MaTt 93 is offline
Old 03-06-2011, 04:57 AM
dburt86's Avatar
do it, with after run oil all you are doing is trying to prevent oxidation.With no air near the engine, you wouldnt have to worry about it.
dburt86 is offline
Old 03-06-2011, 11:06 AM
houston's Avatar
Trader Rating: 96 (100%+)
Thumbs up
Good idea
houston is offline
Old 03-06-2011, 12:14 PM
The_Buggyman's Avatar
thats a good idea im going to do that with a couple of my engines. Thanks
The_Buggyman is offline
Old 03-06-2011, 04:39 PM
Trader Rating: 44 (100%+)
how about ziplock bag?
wyl03 is offline
Old 03-06-2011, 04:46 PM
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
great idea. Im going to do that with my backup motor now!
So*Cal AFDude is offline
Old 03-06-2011, 05:07 PM
JoeGuam's Avatar
I have always done it with my engines especially when I travel with it. Airport inspectors like it when it appears to be safe and is safe. Just do not vacuum seal it completly as you may bend the slide carb. Don't ask me how I know.
JoeGuam is offline
Old 03-06-2011, 05:25 PM
Zip tie the carb closed. Did the same thing.
foxys is offline
Old 03-06-2011, 05:33 PM
JoeGuam's Avatar
I just make sure now that I watch the slide on the carb. No need for zip ties, saving it for air filters tubes. LOL
Yes this is thus far the best way for storing an engine that has seen fuel through it. I personaly clean the engine good and oil it with after run oil and put it away. I have also stored the engine bone dry and never had a problem. I make sure the piston is at BDC and plug removed, that way majority of the air is out of the engine.
JoeGuam is offline
Old 03-06-2011, 06:32 PM
houston's Avatar
thats what i usually do
houston is offline
Old 03-07-2011, 01:30 AM
MaTt 93's Avatar
sealed and ready for storage
MaTt 93 is offline
Old 03-07-2011, 02:29 AM
Roelof's Avatar
I am wondering if some left over nitro (= some kind of liquid oxigen) still keeps oxigen inside to keep the oxidation process working.
Roelof is online now
Old 03-07-2011, 02:53 AM
aussies1129's Avatar
Trader Rating: 74 (100%+)
people living in high humidity and near the ocean will have to take care of there engines alot more, I use to just leave my engines in my shed in the cars and during the day inside temp would get over 110f/40c my nova +4 after 6 months had an unbelieveable amount of rust through it especially the crank. it was totally gone
aussies1129 is offline
