What clutch system For 8ight T
Old 02-27-2011, 07:56 PM
MaTt 93's Avatar
Default What clutch system For 8ight T
Hi,
Im thinking about changing clutch systems on my losi 8ight-T because the stock one wears out abit too to quick for me. anyway, what are the best systems out there? I've heard good things about the werks and the ascendency system? Also if there's a setup i can use on the stock losi clutch that'll give me longer lasting clutch shoes ill be willing to try that too.
Thanks,
Matt
MaTt 93 is offline
Old 02-27-2011, 08:11 PM
Try these:
Team Losi Long Wear Aluminum Clutch Shoes - LOSA9109
bacchus is offline
Old 02-27-2011, 08:13 PM
Trader Rating: 46 (98%+)
i run the dynamite shoes and the last set lasted 3 gallons.
nitroal is offline
Old 02-27-2011, 08:16 PM
alexrckid's Avatar
only the best...................
http://www.amainhobbies.com/product_...-Clutch-System
alexrckid is offline
Old 02-27-2011, 08:17 PM
Suspended
Trader Rating: 202 (96%+)
i like the losi clutch myself, try the shoes listed above, i dont care for the composit shoes, they seem to wear fast. if you are having problems going through shoes, try softer springs, black, green, or gold, silver springs are hard on shoes. what engine you running? knowing that will help awnser your question on what springs to use.
inferno13 is offline
Old 02-27-2011, 08:41 PM
hambone's Avatar
http://answer-rcusa.com/zencart/inde...&products_id=5
Answer-rc works excellent and lasts a long time. Shoes come with 3 sets of springs. Use answer clutchbells also.
hambone is offline
Old 02-27-2011, 09:58 PM
MaTt 93's Avatar
Im using a Mario Rossi tuned Boss 21-off-T. The clutch setup i was using this weekend was 4 aluminium shoes with all black springs and i was having alot of trouble getting over jumps where other truggies were clearing them with ease. The shoes had probably 3 or 4 club days on them. Im looking for some thing thats gonna give me some nice snap when coming out of corners but is low on wear.
MaTt 93 is offline
Old 02-27-2011, 10:00 PM
MaTt 93's Avatar
Oh i've used the losi long wear shoes before but didnt notice much difference in wear.
MaTt 93 is offline
pyromania's Avatar
Trader Rating: 18 (100%+)
You were using the lightest springs available. Go with a 2 green 2 gold set-up on all Dynamite Max-Life shoes.
pyromania is offline
Old 02-27-2011, 10:11 PM
MaTt 93's Avatar
How long have the shoes lasted with that setup?
MaTt 93 is offline
Old 02-27-2011, 10:44 PM
Trader Rating: 7 (89%+)
ascendancy racing have shoes specific for losi system. If its the same material similar to the the ones they are selling they will last a loooong time.
oggietiu is offline
Old 02-28-2011, 04:20 PM
Integra's Avatar
M2C is what i run in Truggy and with a proper set-up to match your Motor and track condition's Ill get Many Gallons from a Single set of shoes with periodic spring changes pending the conditions.
Integra is offline
Old 02-28-2011, 06:20 PM
Are ya'll using the Drake measurement of 23.3mm that when they get that low change them. If thats the case i'd only get like 2 races on a set a of shoes long life or not.
bacchus is offline
Old 02-28-2011, 06:36 PM
hdcruzer's Avatar
I run the green - gold with max lifes and get at least 3 gallons out of them. The stock losi alum. with green and gold I get about 2 gallons out of them.
hdcruzer is offline
Old 02-28-2011, 07:28 PM
pyromania's Avatar
What springs are you using? Are you using a old bell? Is the bell getting cleaned after every race day? Are the clutch pins worn?
There are many variables that contribute to shoe wear.
I personally run Max-Life shoes on the green and gold combo and always get 2-2.5 gallons from the shoes.
