JP-1 pipe OK with B5?....or not
I am ordering a Werks B5 for my RC8b....I plan on running it on a very tight 1/10 scale track, the longest straight is under 30 feet long...So I want a low end pipe.
The only extra pipe I have right now is a Stock Associated pipe from a RTR truggy. I can get a JP-1 pipe from the LHS on clearance...will it work OK on the B5 for low end power? Would either of those pipes do well ? ...If not what would be a good low end pipe to order? Thanks Again |
If you are looking for a good low cost pipe to use with out B5 then just pick up an associate 2035 pipe set. Thuja is probably the best pipe hat you can get for under $50 for that engine. For reviews etc just flip through our B5 thread or do a search.
TTR 2035, Its right around $40 and works great! IMO its the next best pipe for the werks motors besides the 2013/57/58....very cheap, very good
Thanks Again for all your guys help....now the only problem is I bet I will want another for my Truggy:sneaky:
gotta keep it consistant..right:nod: |
