-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   engine problem (https://www.rctech.net/forum/offroad-nitro-engine-forum/483381-engine-problem.html)
NoMercyRC 02-17-2011 07:00 PM
engine problem
hello my nitro engine wont suck any fuel from the tank to the motor. I have tried everything i can think of. The lines are clear an the carb is not clogged. I dnt know what else to do. Can yall help me please.
DPowers 02-17-2011 07:04 PM
Is it possible the lines or missed up i did this once so thats why i ask.
NoMercyRC 02-17-2011 07:22 PM
i check they r good.
VWVR6_T 02-17-2011 07:26 PM
Do you have a filter inside the tank? if you do, might be dirty.
DPowers 02-17-2011 07:26 PM
What engine is it and how old is it.
j_blaze14 02-17-2011 07:44 PM
if you blow in the pressure line does fuel enter the carb? if not may be clogged carb. old dry fuel in the nipple.
The fisherman 02-17-2011 07:45 PM
I just ran into the same thing today,Have not ran the buggy all winter,I did store it properly over the winter,just been to cold around here till today.Then i ranout of daylight.Have one more thing to check,or my fuel could be bad.
NoMercyRC 02-17-2011 08:57 PM
yea when i blow in the pressure line fuel goes to the carb. Could my carb just need cleaned.
22Racer 02-17-2011 09:16 PM
Make sure your starter box is going the right direction.
Rex
houston 02-17-2011 09:25 PM
Open up your high speed needle a few turns , pull open throttle linkage blow into pressure line until fuel flows free , then fire the engine up and turn the high speed needle in until it runs at adequate rpm . Tune from there
The fisherman 02-18-2011 07:48 AM
Houston,
That's one thing I have not tried yet,I will try that tonite when I get done work, thanks for all the info guys.
