Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Can you explain shimming and what it does? >
Old 02-17-2011, 11:16 AM
Trader Rating: 26 (100%+)
Default Can you explain shimming and what it does?
I am running the Losi stock 454 in my 8t 2.0 and was reading a lot on the losi site about shimming the motor... What is this, how do you do it and what does it do for you.
Do I need to do this if I run 30%?
SDelaney is offline
Old 02-17-2011, 01:25 PM
Trader Rating: 24 (100%+)
When you shim the head you could be adding a copper gasket to the head button or taking one away. Adding a shim will decrease your compression, taking one away will increase it. Typically in a non turbo stock mill you want to run a extra .10mm shim when running 30%. If you don't, your window for the proper tune is very short and you could create pre-detonation which can cause unnecessary stress on your wrist pin, rod and crank and it will cause pitting on the top of the piston.
got_nitro is offline
Old 02-17-2011, 09:45 PM
So where do you get shims or can you just use a washer from hardware store?
SDelaney is offline
Old 02-17-2011, 10:53 PM
James khoo's Avatar
Trader Rating: 15 (100%+)
Better to get it from Losi,seen you're run losi engine,the shim are made of copper or aluminium.
copper normally is 0.1mm -0.2mm
Alum normally is 0.3mm
Hope this help.
Cheers
James
James khoo is offline
