sts .21
The "End" that they are referring to is when the needle
is turned all the way in until it just stops.
Set the HSN at 3 turns out.
Set the LSN at 4.5 turns out. (note: make sure that you
have the carb slide opened up when you turn the LSN all
the way in).
Set the idle air gap to .5mm.
the way in).
fa ra ra ra ra, ra ra ra ra
