Ideal run temp for Orion .26 Big Block
What is a good run temp for an Orion .26 Big Block engine. I don't want to be running it to hot. Thanks
It will vary Depending on your location, weather, fuel,pipe plug etc.... but 200-250 is normal, But his is just a general ballpark.
Thanks, Lance RcRenew |
Tune the idle steady and then tune by smoke, as long you have a stream of smoke you are safe. M2C
Originally Posted by VWVR6_T
(Post 8453125)
if your engine is playing funny games on you one day... temp it... it might be able to tell you if you have a tune issue :nod: |
So you should always have a steady stream of smoke coming out or just on accleration? Thanks
You always will have smoke coming out but your main concern should be when accelerate,when you are at the track, there is when you have to look at your tune.;)
