Changing Fuel
Old 01-01-2011, 08:33 PM
Klink's Avatar
Default Changing Fuel
Hey guys will changing fuel after Break in hurt my nitor motor
Klink is offline
Old 01-01-2011, 08:41 PM
jmaxey51's Avatar
no ... if i switch brands, i just rich it a half turn because some may make it to leaner/hotter. then re-tune.
jmaxey51 is offline
Old 01-02-2011, 03:02 AM
VWVR6_T's Avatar
Nope, you migh have to turn the needles a little.
VWVR6_T is offline
Old 01-02-2011, 08:08 PM
j_blaze14's Avatar
Trader Rating: 34 (100%+)
just re-tune, same as changing plugs, compression, gearing, pipes...etc.
j_blaze14 is offline
Old 01-02-2011, 09:03 PM
houston's Avatar
Trader Rating: 96 (100%+)
although some of the different oils in different fuels do not play well with others it would be a good idea to clean the engine out but it should not kill the engine
i like my engines clean , its one of my things
houston is offline
Old 01-02-2011, 09:07 PM
jpalessi's Avatar
Trader Rating: 55 (100%+)
for once agree with HES...
run a tank at low rpm w/o stabbing the throttle. this will flush out your old fuel. not all oils mix with each other and can leave dry spots on bearings etc..
jpalessi is offline
Old 01-03-2011, 02:17 AM
houston's Avatar
Funny joe
Personality differences are different than factual differences ya know
houston is offline
Old 01-03-2011, 04:03 AM
aussies1129's Avatar
Trader Rating: 74 (100%+)
what about using the same brand same olis etc but going from 25% to 30% thats after about 1 gal on the engine?
aussies1129 is offline
Old 01-03-2011, 07:33 AM
Trader Rating: 25 (100%+)
A fuel will cause the engine to have certain wear characteristics due to nitro content and oil used. To change fuel nitro content or brand requires that you "break in" the engine to the new fuel for a tank or two.
smelly62 is offline
Old 01-03-2011, 09:14 AM
VWVR6_T's Avatar
I'm kind of confuse, Why do you need to brake it in the engine when change fuels?
VWVR6_T is offline
Old 01-03-2011, 12:10 PM
Torian4000's Avatar
Trader Rating: 51 (100%+)
You will just need to retune it. It shouldn't take you more than a tank to get the engine adjusted to the new oils and the fuel burning characteristics.
You could just bring it by also Jason if you need help this spring.
Torian4000 is offline
