Vspec break in help!
I am having trouble breaking in my new spec. I can get it to start but when I give it throttle it dies out. I have all the needles set according to the manual. High speed at 2.5 turns out, low speed .5 mm out from flush, mid needle at flush, and idle is 1 mm. Any suggestions?
Originally Posted by ironwalker
(Post 8411208)
re
also leave the ignitor on for a bit wont hurt
I have broken in a few V-specs. You need to get them good and hot before you try to crank them. I usually shoot for at least 180. And your going to need a higher idle for the first couple tanks. After a few tanks it will start to loosen up and it will need a little less idle to keep it running. Make sure you keep the temps up while running the first few tanks. It has been cold here so I wrap tin foil around the head to keep some temp in the head.
If you have the money around 100 bucks I would highly recommend a competition engine heater it will make life so much easier :nod:
| All times are GMT -7. It is currently 06:33 AM. |
