VP POWERMASTER FUEL
Old 01-03-2012, 10:47 PM
  #76
rallyebmx's Avatar
Trader Rating: 21 (100%+)
From BP site
' If you plan to use Powermaster fuel, please contact us before running your engine.'
^That sounds bad My experience with break in was an exrtremely long process with the Powermaster. Couldnt loose the pinch for about 2 gallons. On a real superficial basis...(smell, color) seems like nitrotane with castor
rallyebmx is offline
Old 01-04-2012, 05:50 AM
  #77
Big Will's Avatar
Originally Posted by rallyebmx View Post
From BP site
I am fairly positive that Powermaster is all synthetic oils.
I like the pinch to stay as long as possible. For me it's bad when you loose pinch in 1/2 gallon. Makes me think that the engine will last 4 gallons and then I'm getting a new one.
Big Will is offline
Old 01-04-2012, 07:06 AM
  #78
They state that they mix a syn/castor blend. Would be nice to verify.
http://www.powermasterfuels.com/inde...&id=7&Itemid=9
071crazy is offline
Old 01-04-2012, 02:56 PM
  #79
rallyebmx's Avatar
It does have castor. Anyone find out from BP what they say about running Powermaster? I like running this fuel.
Old 01-04-2012, 03:33 PM
  #80
R/C Tech Elite Member
houston's Avatar
Trader Rating: 96 (100%+)
you guys are talking about the old stuff , the new blue blend is great fuel , i tried it for 12 quarts and thought it was very good fuel , coming from an engine guy
houston is offline
Old 01-04-2012, 04:29 PM
  #81
Jaz240's Avatar
Trader Rating: 52 (100%+)
I did speak to Tommy At VP Fuel and he said the 30% is NOT recommended for break in. He agreed that the lubrication package is more of a racing blend. I have had people use it for break in with no issues but I would imagine it will diminish the longevity of your engine. For those of you here in AZ I will be stocking quarts of the Golden break in blend within 2-3 weeks. Thanks Monty for sending me some additive for the Byrons for break in.
Jaz240 is offline
Old 01-29-2012, 03:48 PM
  #82
Kevin_M's Avatar
Question on this fuel. I have ran a few tanks thru 2 new engines that are broke in and never raced. After the motor is nice and warm and I tune it to performance I get almost no smoke. I dont want to get too lean and blow the motor up but are you guys getting smoke blowing out on top end?
Kevin_M is offline
Old 01-30-2012, 09:59 AM
  #83
Absolutely.
3DRCRACER is offline
Old 01-30-2012, 10:22 AM
  #84
seayya's Avatar
Yes
seayya is offline
Old 01-30-2012, 10:33 AM
  #85
Maximo's Avatar
VP has caster oil ....no doubt about it... I have had to de- gum a engine using it already......I have pictures if anyone is interested......
Maximo is offline
Old 02-01-2012, 12:38 AM
  #86
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
IIRC all RC nitro-based fuels have a mix of castor and synthetic oils in them.
I've got a motor that still runs great with over 14 gallons through it (all Powermaster) and no gunk built up.
Easily the best fuel I've ever run.
heavyjeffd is offline
Old 02-23-2012, 01:35 PM
  #87
seayya's Avatar
A special thanks to Steve Slayden and Mike Battaile with VP Powermaster Fuels for coming on board as the Premier Fuel Sponsor for the AMS 3.0! www.powermasterfuels.com
seayya is offline
Old 02-23-2012, 03:27 PM
  #88
Jaz240's Avatar
That's simply not true. There are quite a few fuels that are all Synthetic with no Castor oil at all.
I have never had any gunk or castor build up in any of my engines using Powermaster fuel either. I am going on my 8th gallon of fuel and I preheat them all.
Jaz240 is offline
Old 06-22-2012, 02:41 PM
  #89
likeaboss's Avatar
Did anyone notice a difference going from the clear to the blue VP 30%?
likeaboss is offline
Old 06-22-2012, 02:43 PM
  #90
kgombe's Avatar
no difference.. i ran the clear stuff for over a year.. and just switch to the blue stuff.. and its just plug and play for me...
kgombe is offline
