6061 or 7075 Clutch Shoes
Old 11-09-2010, 09:19 PM
dnebout's Avatar
Trader Rating: 32 (100%+)
Default 6061 or 7075 Clutch Shoes
What is the difference in clutch engagement? Which one wears faster? 6061 or 7075
dnebout is offline
Old 11-09-2010, 09:43 PM
rallyebmx's Avatar
Trader Rating: 21 (100%+)
6061 is softer, more grabby and wears quicker
rallyebmx is offline
Old 11-09-2010, 10:00 PM
dnebout's Avatar
How about carbon shoes? They're softer but I'm told that they are less grabby.
dnebout is offline
Old 11-09-2010, 10:07 PM
tc5 man's Avatar
if your running truggy there not good to much slip and not enough punch .
i ran king headz 6061 med shoes and they will last about almost a full gallon if taken care of but they do tend to slip depending on what clutch springs you use. and i noticed that they leave a mess as they ware down more and more. now they do grab good though and seem to be easier on the bell.
i would get the 7075 shoes.
tc5 man is offline
Old 11-09-2010, 10:10 PM
dnebout's Avatar
Are the Losi Long Wears and Max Dynamites 7075?
dnebout is offline
Old 11-09-2010, 10:16 PM
tc5 man's Avatar
i havnt, tried the losi long run shoes but they look good i did use the dynamite max 7075 shoes boy they do last i never noticed a slip when i ran them but they are harder.. on your bell though and run hotter but if your running a 15 min main there fine.
they grab ok i had to stiffen up my clutch springs to get more punch from them but they dont leave much mess in your bell .
tc5 man is offline
Old 11-09-2010, 11:11 PM
dnebout's Avatar
I'm running gold and greens with the Max Lifes right now. What did you have to go to on the springs?
I've run the Losi long wear and they are definitely long wearing with gold and green.
dnebout is offline
Old 11-10-2010, 05:54 PM
robbieg's Avatar
Trader Rating: 26 (100%+)
the max life are not 7075 alum. there some sorta carbon ?? mix. they last a good while and i like'm but there not 7075 or 6061. there some different alloy.
robbieg is offline
Old 11-12-2010, 05:07 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
6061 kHz here with green and gold and a out a gallon is right unless I M spinning the .25 then less than a gallon 1/2 to 3/4. The losi long wear are a few $$ more than the kHz stuff too.
Frank L is offline
Old 11-12-2010, 05:39 PM
hdcruzer's Avatar
Dave, Max lifes with green and gold I get about 3 gallons out of them. I know Steve uses the Losi long wears but I dont what he gets out of those.
hdcruzer is offline
