Recommened running temp
hey guys i just want to know what is a recommened running temp for a .28 go motor
cheers Mick |
can someone let me know k thanks
Every engine is going to be different, usually rule of thumb is nothing more then 275f. I personally like mine in the 250f range, but as long as your getting white smoke while on throttle, you should be ok.
Originally Posted by Mick1990
(Post 8110896)
cheers Mick |
Originally Posted by deadmancourt
(Post 8112080)
there is no SAID number...but just make sure it has a good amount of smoke through the ENTIRE powerband...and DONT run @ 300...the .28 motors run great @ or about 240-260 F ....BUT certain circumstances will prove otherwise;)
Originally Posted by losi_racer
(Post 8112758)
you cant say dont run at 300. I know of a guys alpha whos runs at 320 all day long, plenty of smoke,no lean bog. He isnt blowing plugs either. like you said there is no Said number
| All times are GMT -7. It is currently 07:13 AM. |
